Primary metering rods in q-jet
Old Jul 18, 2004 | 09:24 PM
Bird_of_Prey's Avatar
Car: Formula
Engine: 400 sbc
i have a question on the stamping on the primary metering rods in the quadrajet.
mine are stamped 36B
what does this mean, is there a chart i can compare to others and does the rods interchange with jets?
the rod is matched up with a #73 primary jets
Thanks.
Eric
Old Jul 19, 2004 | 02:16 PM
Car: Formula
Engine: 400 sbc
http://www.oldengine.org/unfaq/leadfoot/qrodpri.htm
found this page, in case anybody else ever has this question.
Old May 22, 2005 | 12:17 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Thank you!!!
RS Reaper
Oct 17, 2018 07:52 PM
Ed1LE
Sep 30, 2018 09:14 AM
thunder57
Nov 7, 2015 02:28 PM
LT1Formula
Oct 8, 2015 08:34 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
