Dont know need some opinions from some pros and newbies
Old Jul 19, 2004 | 01:57 AM
tbfirebird's Avatar
Car: Black 89 Formula
Engine: ??????????
Transmission: ??????????
Okay heres what i had a stock 305 tbi with a 700-r4 stock converter and 2.73 gears. now i got
MOTOR.
97 LT1 cam and 416 305 H.O. heads portedmildly and 3angle valve job and polished and 1.94/1.60valves/and spreadbore intake stock factory one with blocked egr port and a edelbrock600cfmcarb and the timming is at like 13and a half to 14advanced.with HEI distributor/
DRIVETERAIN
2.73's open rearend stock converter stock tranny 700r4/
what i want to now is what i should do next to the car only pulls from about 3k and up if but then my fuel pump dies sometimes at like 4or sometimes 5k and sometimes it wont die.what type of fuel pump should i get a mechnecal or eletric/also what gears do you recomend.
i jus wanna be in the low 14's or if possible 13's intill i get my 383/ oh yeah the car isnt going to be used for dail driveing so gas mileage isnt a problem i got a lil rustang beater. 4banger baby.
Old Jul 19, 2004 | 01:34 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You need a converter that stalls at 3000 RPMs. Then, when you nail it, it'll be in the powerband already.
Assuming you have a stock fuel pump, either get an upgrade pump (aftermarket or TPI), assuming you have an adjustable regulator; or take out the in-tank electric pump and put a mechanical on the engine (although I don't recall off the top of my head if the LT1 cam has a fuel pump lobe).
Gears - if you get anything higher numerically than 2.73, you're going to want posi. 3.42 or 3.73 would do nicely, I'd think.
Old Jul 19, 2004 | 11:38 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
If you have the stock in tanks tbi pump it should work fine for your combo aslong as your using a bypass style regulator. There maybe a prob. with your pump. Also the lt1 cam doesnt have the lobe for the mech. fuel pump pushrod. First I would get a performer rpm intake that stocker is killing performence for sure. I also assume you have a full exhaust with headers and high flow or no cat right? I would recommend 3.42 gears or higher aswell, you dont really need a stall but that would give you some extra go, but really with that mild of a cam I wouldnt get an aftermarket one as long as you have some shorter gears.You should defenetly be able to go low 14's with what I mentioned and a good tune. First find out what is wrong with your fuel pump because my tbi pump pulls about 6psi easy up to 5500 rpms with my mild 350. Good luck.
Old Jul 27, 2004 | 10:37 AM
tbfirebird's Avatar
Engine: ??????????
i have the stock 2 1/4 tail pipe which is ****ty as hell also how long do head gaskets take to seat and do i have to retorque them kuz lately when i floor it they been getting kind of smokey.
Old Jul 27, 2004 | 12:50 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
head gaskets don't "seat" . they either seal up, or they don't. If you want to retorque the head bolts go ahead.
Unless you're loosing water the smokey exhaust is probabily not, head gaskets.
Old Jul 27, 2004 | 10:32 PM
tbfirebird's Avatar
Engine: ??????????
it only seems to do it at top end alot but latley it started to do it more and more lower rpm like around 2k or 3k
ill notice it
also what heads gaskets do you recomend for cast iron heads and block of course.and should i use anything else on the gaskets or bolts?
Old Aug 4, 2004 | 09:54 PM
Lonestar's Avatar
Car: 1985 Firebird
Engine: 327
Transmission: TH350
If you can't break the 2.73's loose with an open differential, you are underpowered. Learn how to tune the engine properly then go from there. The smoke on acceleration is a hint to this or a problem with the engine...hope it is a tuning issue.
3.42 to 3.73 posi rearends (depending on your engine) seem to do well in these cars. The stall converter will help, but be sure the engine is tuned properly first prior to choosing, and remember that a stall rating is generic...your engine will determine the actual stall of the converter.
Old Sep 10, 2004 | 06:02 PM
tbfirebird's Avatar
Engine: ??????????
found out my head gaskets werte up side down so yeah thats why i was seeing smoke coming out of the motor.so i got the fel pro gaskets (blueones) and got it all done have to but the motor at TDC then do the timming at about 13 advanced with va unplugged. also gonna have the fix that fuel pump issue it dies sometimes at around 4500-6k and sometimes it wont.what intake do u guys recomend i got an edelbrock 600 cfm carb.
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
cheesehomer
Dec 31, 2015 08:48 AM
skinny z
Oct 5, 2015 06:23 PM
Jlanz55
Sep 29, 2015 08:55 AM
