83 dying on acceleration
Old Jul 27, 2004 | 05:33 PM
Tranzamman's Avatar
Car: 85 Firebird
Engine: 468 BBC
Transmission: Turbo 350
Axle/Gears: 3:73
1983 Camaro 2.8 carb'd ...
only under a load will it die but feels like a fuel starvation problem -- anyone got the specs for a fuel pumps pressure ?Im going to check the pressure tonight and will get back on later hopefully ill have some #'s to compare it with .
Old Jul 27, 2004 | 06:04 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
4 to 6 psi is typical for carbs in general. You need to monitor it under the conditions which have the problems.
Depending upon where you tap for the pressure, you may or may not have a pressure issue. Have you changed the fuel filter lately?
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Luigytico09
Oct 1, 2015 08:46 AM
