cc carb problem, guru's inside please...
Car: 1987 F150...PAAARTY FOUL!
Engine: 300 I6 stump pullin sumbiscuit
Transmission: 4 speed grind box
Axle/Gears: 3.55 unlimited slip differential
i have a pretty big problem with my Z28. at higher RPM's in gear, usually the top end of second, it runs out of gas. i thought it was the fuel pump, but it seems more like a carb problem. it completely runs out of gas, no matter how much is in the tank. anyone ever had this problem with the CCCarb? if so, what was the problem? i am most likely installing a 650 Edelbrock, but still i am curious...
Josh
Josh
a fuel pump should be more consistant...a carb problem would be off and on like this...at least i would think so...
Josh
Josh
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If your fuel pump isn't delivering the required volume, you'll drain the bowl and run dry.
Transmission: 4L80E/4L80E
The closest it could possibly be to a carb problem is a plugged fuel filter. A weak fuel pump (or plugged fuel filter) will keep up when demand is low ("normal" driving), but not at WOT.
Been there, done that with a stock 1986 LG4. An AC replacement pump in Sept 1999 cured the problem, it's still on there today.
A 650 Edelbrock would be a BIG mistake. A smaller overall carb w/larger primaries, w/o feedback, no more TCC lockup, less power potential, poorer fuel economy - in the end you'd be $400-$500 poorer and still need a fuel pump.
Let's be clear on the operating theories here: The fuel pump on a carb'd engine doesn't do the same thing as the fuel pump on a fuel injected engine.
For FI, it has to supply pressure constantly, or the injection won't operate properly. (It's still possible to have a volume problem with a FI pump at WOT but not normally, though.)
With a carb, the fuel pump fills a reservior in the carb, then stops pumping (techinically, it returns the excess to the fuel tank, but that's what the carb sees). It doesn't operate on "pressure". The carb draws from the reservior as needed. When you get on it for a short time, it can lower the level in the reservior w/o depleting it, so it can seem to continue to run okay. But, if you stay in it, it'll go dry if the pump isn't keeping up. The worse the pump is, the sooner it will go dry. Mine would do it at the top end of 1st gear.
Replace the fuel filter at least - it'll probably continue to do it and you'll find you need a fuel pump, too.
well, i tihnk i am gonna go with my friends Holley 650 DP. i am just gonna replace the fuel pump at the same time...as for feedback...umm, im GLAD that will be gone. as for the TClockup, i will put it on a switch. and the 650 was only gonna cost me $100 from my friend pretty much new. i am getting the Holley for $80...
Josh
Josh
theshackle
Mar 5, 2017 06:37 PM
92camaroJoe
Aug 13, 2015 06:07 AM
