corroded carburetor
Car: 88 camaro SC
Engine: 305 t.oilet b.owl i.njection
Transmission: rebuilt 700r4
corroded carburetor
i got an edelbrock carb from a friend, and i have a couple questions about it. --first of all, how do i tell what model it is and everything without him knowing either? -- and also, its kinda corroded. its not like horribly bad, i can probly polish most of it out. its on the carb itself all over the place, 2 of the throttle blades are rusty, and only like one of the levers or whatever move freely. can i clean it up and restore it to like new condition with polishing corrosion removal and probably a rebuild kit?
i dont know a whole lot about carbs and my car is tbi, but im rebuilding the engine and have a nice carb intake, so if i get it to work nicely i might swap thanks
dan
dan
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Model number is stamped on the front right mounting ear. Disassembly and cleaning would be a start, anything that doesn't free up after that would have to be replaced.
Car: 88 camaro SC
do you have any recommendations on how to clean it up? especially in those tight hard to get to spots?
Engine: 383 Carb
Transmission: 4L60
Disassemble everything and soak the non-plastic parts in real carburetor cleaner. Scrub as required.
Elephantismo
Feb 13, 2019 12:51 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
