Another Carb Swap, HELP with Fuel Pump!!
Old Sep 27, 2004 | 05:18 PM
SnkSknrZ28's Avatar
Car: 1988 Camaro IROC-Z
Ok, my buddy's switching to a Carb, he does not want to go with the Mallory 3port deal. What other options are there for a fuel pump, he kind of wants an electric external pump but i'm not sure how to hook it up, use the stock fuel lines?? They seems kinda small to me. Plus he's gonna add Nitrous down the road and the fuel supply to the motor would scare me a bit.. Any other suggetions guyz?? Ideally i'd like an external pump (inline?) and new braided fuel line ran upto the motor, but i can't figure out how to connect it to the tank without welding on a sump..
I did it different on my motor, i bougth a new tank, welded on a sump and i'm running a holley blue pump, however he wants to run his flowmaster catback and the sump sits right where the muffler does so that eliminates that deal..
Thanks guyz,
Mike
Old Sep 28, 2004 | 10:22 AM
SnkSknrZ28's Avatar
I read in the tech articles about anther way, the way that requires you to remove the gas tank. He talked about running an electric pump, carter, holley, etc.. But how would you connect the lines to the tank, just drill into and and put an adapeter? suggestions?
Old Sep 28, 2004 | 10:33 AM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
with all the extra work involved in saving 79 dollars for the regualtor will cost you more in the long run..
the stock 3/8 feed is enough for 500 ponies....there are guys on this board with almost that amount of power with stock lines...
either
A). use the stock or upgrade stock type pump with the mallory 3 port
B). sump the tank and use what ever you want...
Old Sep 28, 2004 | 12:32 PM
ljnowell's Avatar
Why not just take out the factory pump in the tank, mod the pickup (insert piece of line where the fuel pump was), and install an inline electric? You can get them the put out the right pressure for a carb. Then you wont have the regulator issue. Or you could just use the regulator. If you are going to run a carb though, why not just use a mechanical pump? Lot simpler, Lot cheaper, makes sense.
Old Sep 28, 2004 | 03:02 PM
z28monster's Avatar
Car: 86 IROC-Z
Axle/Gears: 3.42s/posi/disc
cant you just pull the old feul pump fuze.. then put an inline electric carb feul pump up on the fire wall or something like that and have it pull the feul through the old pump..... im pretty sure this would work
Old Sep 28, 2004 | 03:08 PM
ljnowell's Avatar
No it wont work, at least not properly. Some people have done it, and it will function, but usually always gives them problems. Not to mention that it wont pull an adequate amount for most engines. So, no it wont work.
Old Sep 28, 2004 | 06:33 PM
SnkSknrZ28's Avatar
Thats the kind of idea i have inmind right now. Have any of you done this? Or no anybody that has some pix to give me an idea?
Mike
Old Sep 28, 2004 | 07:04 PM
ljnowell's Avatar
I dont have any pictures, But I have done it many times, on lots of vehicles, not just thirdgens. Its pretty basic. Take out the pump, modify the pickup, Find a good spot by the fuel lines to mount the pump (most people just outside the tank, on the flat spot), and splice it in. Oh yeah, you will need to hook up power, either by splicing into the factory, or running your own. Not very hard, and there are a few threads here with very detailed instructions.
Old Sep 29, 2004 | 01:56 AM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
I wish I had the option to run a mechanical pump on mine. If so I would have one already. Damn my caprice 350ci and its no hole for the fuel pump rod
Old Sep 29, 2004 | 10:28 AM
Damon's Avatar
Hold on- no fuel pump pushrod hole?? Really?? I haven't run into any 80s era SBCs that didn't have a fuel pump pushrod hole. Sure, the block off plate on the outside of the engine must be swapped for one off an earlier carbureted setup that has a hole in it and a fuel pump pushrod must be procured, but the blocks I've used have ALL been drilled for a fuel pump pushrod and the cams have likewise had a fuel pump eccentric on them (even if the cam was originally used in a FI application).
Old Sep 29, 2004 | 12:07 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I believe he's speaking of the SDPC Caprice crate engine. The boss is cast, but the holes aren't machined. Same for LT1's, from what I've gathered.
Old Sep 29, 2004 | 12:12 PM
ljnowell's Avatar
Thats screwed up. They are trying to take away my mechanical pump! Damn them.
Old Sep 29, 2004 | 12:19 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
thats the same way on my 88 gmc 305 factory engine but not machined out but cast there .....go figure..
Old Sep 30, 2004 | 10:13 PM
Transmission: 4l60e
Hes right I have the caprice crate engine. It looks like I could mount one...but there is no hole.
I couldn't run one with my lt4 cam anyways...no fuel pump lobe.
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
