TPI to 350 carb engine CHARGING problem
i recently rain across an 86 IROC that has been converted from TPI to a carburated engine (350) and i have a CHARGING problem. we have replaced the battery and alternator 2 x's each.....we have 12v running to the alternator BUT, 0 volts coming out of it!! needless to say, it won't hold a charge. could the car's computer be causing this? i read something similar on this site (but there was no TPI/carb conversion) and it mentioned the cable running to the started being bad......will/can someone please help me?
p.s. i do not know WHY it was converted to carb, i would have left it alone.
Car: 83 Z-28 (Original owner)
Engine: 305 CC-carb
Transmission: Richmond 6-speed, Rear:3.73
Try asking this on the "Electronics" board. I don't think the ECM has anything to do with the Alt. If your 86 is like my 83(factory carb), The big red wire on back of Alt has 12 volts all the time, its hooked straght to the battery. The 2 wire connector has a small red wire that is hooked to the same post as the big red wire, the other wire (black) is hot (12 volts) when the ignition key is "On".
Without this 12 volts, the Alt won't put out any power.
Car: 1986 Irocz
Axle/Gears: 3.25:1
It has nothing to do with the computer.
Either the (2)wire plug isn't connected properly, or
the voltage reference wire was disconnected or lost.
If you can't repair the wiring then swap to an externally regulated alternator & you'll have no more problems.
Engine: 305 CC-carb
Unplug the Alt connector and turn the ign key to "run". You should have 12 volts on both wires that plug into the Alt.
theshackle
Sep 17, 2020 08:26 AM
theshackle
Mar 5, 2017 06:37 PM
db057
Aug 11, 2015 10:11 PM
