dash board gauges not functional
ok....i bought an 86 IROC that had been converted from TPI to carburated 350cid. none of the gauges work (speedo, fuel, temp, RPM, etc). i was told that since the TPI & computer were removed that the gauges would not function 'cause they were run by the computer itself. how true is this? IF true, can i get an aftermarket set for my car? thanks in advance....
Car: 1982-z-28.1987 sc
Engine: 350 on z-28,305 on sc
Transmission: bw t-10 on z-28,700r4 on sc
well,the speedo in your car should be cable operated,so it's not affected by the computer,its probably dissconected,was the instrument panel removed?,check if its properly attached to the car,check your intake manifold and look for the temp sending unit,it should be located next to thermostat housing or in the block under the ex.manifold drivers's side,check if it's connected,
im sure some of the other members can be more helpful,so lets see what they come up with
Car: 90 Camaro RS
Engine: 6.3L 383 V8
I did the tbi to carb swap. All my gauges work fine. The emc is sitting somewhere in storage so that has nothing to do with it. I would try whay phess11 and sr. bond suggested. Oh but of course your torque converter will not lock up.
Car: 1984 Z28
Engine: L69 305 HO
Transmission: 5 speed manual
Axle/Gears: Auburn pro yukon 3.73 gears and axl
the computer controls engine functions ,cruise control,and fan control,at least on a 1984 Z.I did computer delete,see sig but my gauges worked fine.Until I turned the lights on,then I lost Tach,Oil pressure,and ammeter.but that was not due to comp delete.
what are the advanatges over carb vs. TPI? i really would have liked to have had it original (TPI) but, it was too good of a deal to pass up.....at the time, then the nightmares started!
if i wanted to go back to TPI would it cost me an arm and a leg? all the wiring and other stuff has been yanked out......
Car: 90 Camaro RS
Engine: 6.3L 383 V8
Carbs are raw power. Instead of a computer telling my engine whats good for it, I tell it. There's a reason why top fuel and nascar still use carbs. Well thats my
anyways. However, I would be lying if I didn't say there are days when EFI would make things a little nicer. Mainly long trip with no CC.
anyways. However, I would be lying if I didn't say there are days when EFI would make things a little nicer. Mainly long trip with no CC. Thread
Hotrodboba400
Dec 10, 2019 07:07 PM
