Not sure If this is normal
Old Dec 2, 2004 | 05:36 PM
83_Camaro_83's Avatar
Car: 1987 Z28
Engine: Tree Fiddy (modded)
Kay, on my carburetor, (2 barrel) one barrel flap thing (sorry for terminology) is always open! i turned off my car and it was still open! It is te smaller of the flap things.....is this my choke plate? If so does that mean it is stuck? cause i do get crappy fuel milage. And how can i tell if my carb is electronic or not? pics of the difference in the two would be great Thanx guys
Old Dec 2, 2004 | 05:48 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Now that you mention it, I've never heard if the Canadian V6's were computer controlled or not.
Sounds like you choke is open, but it should be when the engine is warm. You need to check it when the engine is stone cold, hasn't been started, and the throttle had been opened slightly. Being stuck open would make it hard to start, not give you poor fuel mileage.
Old Dec 2, 2004 | 05:50 PM
Car: 1987 Z28
its is sometimes hard to start only in the mornings though
Old Dec 2, 2004 | 07:28 PM
nsimmons's Avatar
They're not computer controlled. I had an 84 2.8l and the choke linkage stuck one day and it got terrible mileage, but yours sounds stuck open. Is it idling to high?
Old Dec 2, 2004 | 10:20 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Thats danm near a dead giveaway of a stuck open choke.
Old Dec 2, 2004 | 11:02 PM
Car: 1987 Z28
It idleing normally....but is it really a sign of a stuck open choke? how do i fix this??? thanx for the replies everyone
Old Dec 2, 2004 | 11:51 PM
Air_Adam's Avatar
Does it idle kinda rough and 'touchy' untill its got some heat in it? Before I got my Qjet's choke to work when it had problems, it was always stuck open. It always did start, but would take awhile, and it was very touchy untill the engine had a little heat in it.
Old Dec 3, 2004 | 10:34 AM
Car: 1987 Z28
YES thats exactly what is wrong, it will stumble until there is some heat in the engine, today in the morning i started it (took 10 seconds, a record) and then it stalled half way up the road. Then it started up again and the idle stayed actually prettylow......so i dunno if this is the problem.....thanx again
Old Dec 3, 2004 | 04:05 PM
Air_Adam's Avatar
Yup, thats exactly what my engine did too. Fix the choke.
Old Dec 3, 2004 | 09:14 PM
Car: 1987 Z28
how does one go about fixing this "choke"
Old Dec 3, 2004 | 10:10 PM
ljnowell's Avatar
Easiest way would probably be a manual choke, the best way would be an electric choke. Really, they are just as easy as a manual choke to install too.
Old Dec 4, 2004 | 10:26 PM
Air_Adam's Avatar
I'm not sure what the carb on a V6 is like, but on my Holley (I dont remember the Qjet well) there are two things you do. I think its basically the same for most carbs.
There is a screw behind the electric choke setup, near the bottom of the carb. This is the high idle screw. It looks something like the idle speed adjustment screw, complete with the spring over the threads, but its smaller. You adjust this so that when the engine is started cold, it will idle high untill its got some heat in it, usually around 1200-1500 rpm.
There is also the choke adjustment itself. On my Holley, and my Qjet, it was a big round black thing on the pass side of the carb with one wire going into it. This adjusts the choke plate itself. You have to loosen it up (usually 3 screws, but some have rivets) enough that you can turn it. On the Holley, you turn it counter-clockwise to richen it up, meaning the plate closes more and for longer, and clockwise to lean it out, meaning the plate doesnt close as much, and opens up quicker. I can't remember if my Qjet was the same, but it probably was.
Fanatic1074
Oct 3, 2022 05:57 AM
Linson
Oct 1, 2015 09:50 PM
dusterbd
Sep 29, 2015 08:40 AM
BWilcox
Sep 20, 2015 12:19 PM
Stroopwafel
Sep 11, 2015 06:38 AM
