TPI to Carb switch. What do I need?
Old Dec 12, 2004 | 10:41 AM
waldershrek's Avatar
Car: 85 Z28
Engine: 383 Stroker
Transmission: 700-R4
I currently have a Super Ram TPI setup, however, I will be switching to a carb setup over the winter and I don't really know exactly what I will need. I have the intake manifold already (Edelbrock Performer RPM) but I don't know what size carb to purchase, nor do I know if I will be able to use my in-tank fuel pump that is stock (85 Z28). I'm sure there are going to be some other little odd parts that I will need as well. Any help?
Old Dec 12, 2004 | 12:29 PM
ljnowell's Avatar
You can use your in tank pump, you just need a 3 port regulator. Mallory I believe makes the one that most people use. You will need a non-CC distributor. It's commonly referred to as an HEI distributor. You can pick them up from summit or jegs for a decent price. Right now I believe on the back cover of the jegs christmas catalog they have one for 99 bucks. Hell of a deal. You can also junkyard it for one. I have done it before, just give it a thorough lookover and makes sure its all OK. I see you are running a 383, so you probably wont want a stock ignition. If you went junkyard, you would need a new module, coil, cap, rotor, etc. Your best bet is probably a new one. As for a carb, its a wide world. A lot of it depends on your combo. A wild *** guess? For a nicely built 383 I would say a 750 of your flavor (Holley, demon, edelbrock, rochester, etc.). If you follow the commonly accepted formula of VE = (displacement x rpm)/3,456
you can get a ballpark figure. Allowing a 383 @ 6500 RPMs, you would need a 720, so in essence a 750. However, this equation assumes 100% Volumetric efficiency, something you really wont see. Most engines achieve around 85%. So you could probably do fine with a 700cfm carb.
Old Dec 13, 2004 | 05:06 PM
Car: 85 Z28
Engine: 383 Stroker
Now I also have a 700-R4 tranny that in computer controlled. Can I still use this or will I need to switch something? I saw a kit in jegs for a 700-R4 that switches it to non-lockup or something, would this be what I need?
Old Dec 13, 2004 | 06:44 PM
ljnowell's Avatar
The trans isnt computer controlled, the lockup converter is. You can buy a kit from summit/jegs/PAW or wherever that allows you use of the lockup converter. You can also do it yourself for about a 1/10 of the price. Just do a search on these boards for Lock-up converter or "carb swap Lock-up" you will find it easy. There are many threads dealing with it. Its not very hard to do either.
Old Dec 13, 2004 | 07:03 PM
GTAfanatic's Avatar
Car: 1988 GTA Black notchback
Engine: 1991 L98 355 TWIN Superchagred
Transmission: 700r4 shift kit 2500 stall
Axle/Gears: www.cardomain.com/id/gtafanatic
What exactly is a lockup converter
Old Dec 13, 2004 | 07:14 PM
ljnowell's Avatar
Simply put a lockup converter is a torque converter. Its just a type of converter. It "locks" and provides better economy. Running without a lockup converter is kind of a no-no. Another one of the reasons I dont care for 700R4s. But its easily circumvented.
Old Dec 13, 2004 | 11:15 PM
Car: 85 Z28
Engine: 383 Stroker
Will a different tranny bolt up to my setup. The console shifter and everything is stock and if so what tranny would be the best to put in. I would like to have overdrive though cause I do drive on the highway a bit.
Old Dec 13, 2004 | 11:24 PM
Rick King's Avatar
Car: 1987 TA
Engine: 350 stock/twecked
\I did this this past summer and went witha SBC 350 with 882 heads mild porting and 1.6 rockers- the only thing I see left out is that you will have to wire up the heater controls differently as the hot wire runs through the TPI system, at least mine did and it was a 1987 TA WS6. B&G makes a regulator that will reduce your fuel pressure enough to let your carb live!!!!!!!!!
later and
GB
PM me if you have any futher questions
later
RK
Old Dec 18, 2004 | 01:18 AM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
If u want to stay with overdrive your only real options are the 700r4 or like a 4l60 trans which the 4l60 would be stonger. Most of the later transmisson are electronically shifted anything with an E at the end of the title. I would stay with the 700r4 until it broke then i would decide. A turbo400 is strong but u give up overdrive.
Old Dec 18, 2004 | 07:54 PM
Rockin-Iroc's Avatar
Car: 1986 IROC-Z
Engine: 355 ci TPI, 10:1 cr, Isky cam, ported heads, dual exhaust
Transmission: 700R4, ratchetting shifter, 3.23 rear
You do if you overdrive it. Check out www.gearvendors.com for details.
However, the 700R4 is a nice transmission. 3.06 first gear and a good overdrive. Call Summit as suggested above, see what they recommend. I think there are also kits to maintain your lock up for retrofitting this transmission into older cars that never had it.
You might also try TPIS. I'm not sure what they have, but they may dabble in that too.
The lock up feature in the torque converter simply locks up the coupling between the engine and transmission to stop it from slipping. Torque converters are supposed to slip, it is part of their design. The amount of slippage can be tailored to allow your car to launch at an rpm closer to your torque peak. The stock torque converter can be modified to stall at about 2200 to 2400 rpm and still maintain its lock up feature.
The lock up is supposed to boost fuel economy on highway cruising by as much as 2 mpg. But it won't hurt your transmission at all by disabling it. That's probably what most of the muscle car guys do when they install this overdrive automatic in their older cars.
gta90
Sep 15, 2015 04:00 PM
beachrodder
Aug 25, 2015 08:05 AM
theurge
Aug 21, 2015 12:46 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
