Quick question - ZZ4 intake manifold and LG4
Car: 1999 Saturn SL2
Engine: 4 cylinder
Transmission: 4-speed automatic
Will the ZZ4 intake manifold pretty much bolt onto an LG4 that's otherwise stock? Or does it require that some things need to be remove/changed other than the stock manifold?
I have an opportunity to get this intake manifold for cheap and that's why I am asking.
Car: 87 Black Formula
Engine: Rollercammed Lg4
Axle/Gears: 3.23 10 Bolt Locker
There are some differences on center bolted valvecover heads and perimeter bolted, so if you have the stock 84 heads, make sure it's the manifold is for a -86 down and not 87- up. Other than that it might work, but I was under the impression that the ZZ4 was a new intake made for the new heads.
Engine: 4 cylinder
Chevy says it's compatible with any block up to 1986, so I'm not worried about that. I was wondering if there were any things that would need to modified in order to bolt it right onto the engine (e.g. EGR, waterneck, ect.).
Car: 4
Engine: 6
Transmission: 5
The ZZ4 is a much better intake than the Performer.... I have one of those too, had them sitting side by side to compare; also a Perf RPM. The Performer isn't much better than what came on these cars.
It's a decent intake, and for emmisions it's good, but the RPM is a much better piece. GMPP intakes are made by Edelbrock. I've used all three (and then some), and I'm sticking with the RPM for dual plane apps. I couldn't tell the difference between the ZZ4 and the Performer, but the Weiand Stealth amd RPM both worked better. Never had a stock LG4 intake so I'll have to take your word on that one.
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I also have one of these (ZZ4 intakes) on my car at the moment...bone stock as far as whatever bolts to the intake and around it.
Engine: 4 cylinder
Ok, thanks guys.
Does the Performer RPM offer enough of a performance increase over ZZ4 intake to consider buying it instead?
I'm aware that the car is stock and it probably won't make too much of a difference either way, but I plan to do some extensive work later on down the line.
Engine: 4 cylinder
No emissions, but I don't know if I want to get rid of the EGR if it is too much of a hassel.
My car's engine isn't, and probably never will be, comparable to a ZZ4 either.
I think for now I will just stick with the ZZ4 intake and if I feel the need to upgrade later on then I'll do it then.
Thanks for all your help.
ambainb
Apr 25, 2016 09:21 PM
