Regulator
Car: 85 Berlinetta F41
Engine: 355
Transmission: TH700
Axle/Gears: 3.73 posi
Regulator
I'm looking for a return style fuel pressure regulator.. preferably adjustable.. anyone have a part number for one? I cant tell waht I need by the descriptions on summit or jegs.. please help.
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Carb of EFI?
There's many different brands and configurations so your application will kind of dictate some options to look for.
Are you planning on installing nitrous someday, turbo/super charged that'll weigh in also.
What size fuel pump? what kind of hp you guessing?
Answer those and we can get you narrowed down to some specific part numbers.
Engine: 355
Transmission: TH700
600 holley VS, holley mechanical fuel pump, supposed to be regulated at 7psi, but still dead heading without a return.. 307sbc, maybe nitrous some day but I dont need the boost referencing type for now.. my geuss would be about 250hp at the fly for now, maybe less. just didnt see any return style regulators on the net.. thanks for the help, im lost here.
Realistically your fine with just a standard regulator, but you want return port so take a look at a few of these.
These will all be Jegs P/N since that's where get 90% of my stuff.
P/N 650-4309 Mallory 3 port return style 3-12psi $ 74.99
P/N 027-13301 Aeromotive universal bypass style 3-20psi, you can just put a plug cap over the reference port $115.99
P/N 793-30-900 Quick Fuel bypass style $71.99
All 3 of those use 3/8" NPT ports so you dont have to get into the expensive AN fittings. Any one of them will work for your application.
Engine: 355
Transmission: TH700
I really appreciate your help! I think I will go with the mallory.. only a few bucks more than the quick one and I've heard of mallory, but not quick.. thank you for your time and expertise IHI!
Transmission: 4L80E/4L80E
The Quick Fuel adjustable secondary housing is the only way to run a VS carb, IMHO, if you must run a VS carb.
Engine: 355
Transmission: TH700
Looks like the quick also comes with mounting hardware... is there any way I can use metal lines, or what is a decent hose to use?
You can use steel lines going into the reg and bck to the tank, but use some sort of flexible line going to the carb, just makes pulling the bowl off for jet adjustiment alot easier with no chance of stripping it out.
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i'm running the mallory 4309 on my camaro and am happy with how it works.
gixxer92
May 18, 2017 11:20 AM
Royal_Z
Sep 30, 2015 08:45 PM
Dragonsys
Sep 25, 2015 03:51 PM
