Which Carburetor?
Car: 91 Firebird
Engine: 3.1 V6
Transmission: TH-700-R4
Which Carburetor?
Whats the best carb to use on an 89 Firebird Formula with LT1 350 Block with .202 heads and hydraulic cam?
I was told Holley double pumper 650 or 700 cfm.
thanks
thanks
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
.202 heads??? do you mean the intake valve is a 2.02"? what are the numbers off of the head and the specs on the cam? are their any other upgrades to this 350?
Car: 91 Firebird
Engine: 3.1 V6
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
daily driver, you can get away with a 600
race car, I'd go with a 750.
Car: 1986 camaro
Engine: 383 sbc
a 650dp will serve you just fine. what about a factory q-jet?? any thought about using one of those. They support a decent stock 350 fairly well.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Got any more specs on your mill? Going off the info we do have, I'd say a 650 is about right if you are using a manual secondary carb.
Car: 87 chevey camaro
Engine: 355 weiand supercharged
no matter what you do go with a holley or demon. do NOT get a quad jet or edelbrock lol they r for cruisers u will not get power from the.... i would go with a 700 cfm or 750 u can always adjust the jets accordingly id rather have a little bit to much carb then not enough
Car: 1986 camaro
Engine: 383 sbc
Re: ..
WhteRbt
Sep 21, 2015 09:48 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
