Is this okay
Car: '87 iroc camaro
Engine: 350 L98
Transmission: 700-R4
Axle/Gears: 3.27 posi
Is this okay
i have just brought a '83 Z28 camaro with a L48 engine transplant. Its got the 700 R4 auto box. My question is about the carb set up. The car has currently got a 0-1850 4 barrel Holley carb but in the manual it states that this carb is not designed for any automatic overdrive trnsmissions. Its also states that severe damage will occur if fitted. Is this info correct? should i remove the carb? if so then what carb will work well with the L48 engine.
Engine: 350 L98
anyone ???
I am booked in for a rolling road session and i dont want the guy to rag the hell out of it if the carb if its unsuitable.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
IIRC, that has something to do with the kickdown cable hookup (or lack of). I don't know if theres any way to make it work though, I'm not too familiar with autos.
Engine: 350 L98
what does iirc mean ?. can you recommend any carbs that would work well with the L48 engine and 700 R4 auto box
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
IIRC = if I remember correctly
A qjet would work
Check with holley, there should be a part available to add on a kickdown cable
A qjet would work
Car: 1982 Trans-Am
uh oh, you're a few steps back there eh?
The q-jet was the factory carb on that car, which would have worked with the factory transmission just fine... (The 700R4 wasn't factory that year was it? ) Well, it'd probably still work..
That would be an easy swap, but it kinda depends if you intake manifold would accept a spreadbore carb.
However, first step would be to try and use that carb, I don't know anything about holley, maybe someone else here can help you, but perhaps you can purchase the correct bracketing for it?
Might be easiest.
Might be easiest.
Engine: 350 L98
thx sonix for your help. I think your right why fork out for a new carb if i can use the one i've got right. from what i have been told the main thing is the TV hook up. I think this one worrants a trip to a transmission specialist.
Car: 1982 Trans-Am
I suppose... It's more of a carb then trans thing though, kinda an inbetween problem. Well good luck, it's weird no one else has posted about this, i'm shocked that no one else can give better advice than I could about this
Car: 1985 Camaro Z/28
Engine: L69
Axle/Gears: One-Wheel-WOnder 3.08
I used to have an 1850 on my car- transmission worked just fine. I just welded on a little ball to hook the kickdown(TV) cable to the throttle. It is very important to get the TV cable set right. I you don't feel comfortable, take it to a tranny shop and have them set it. That is, if you decide to go with the Holley.
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
whoever put that carb on the car may have made a TV cable bracket for it. Look at it and see if there's a TV cable attatched to the throttle lever on the carb. Chances are that if there is no cable at all then the trans would have blown up all ready or at least be slipping it's a$$ off.
Engine: 350 L98
up until a few days ago the car had been sitting for 18 months. i have changed all service parts and it is due to go in for its M.O.T, UK's vehicle test, next week. One thing i have noticed is that there is a tranny leak every three or four days ther is a pool of transmission fluid about 1" square, the fluid itself is very clean,. Could this be contributed by the carb not being set up
Engine: L69
Sounds like maybe a leaky transmission pan gasket. I doubt that your carb setup has anything to do with it.
Engine: 350 L98
Car: 92 firebird
Engine: 350 lt-1
Transmission: 700 r-4
if that makes your heart stop glad yer not in my shoes. But make sure the kickdown cable is set right, lost a trans because of that. Then it will make your heart and your car stop.
