idle mixture screwed?
Old May 7, 2005 | 07:47 PM
MTCAMARO's Avatar
Car: Camaro sc
Engine: 350 cid.
Was checking my idle mixture screw settings today and found that the pass. side screw had no effect on the vacuum or idle at all,and the driver side screw was very responsive and i set it accordingly.Is this normal on a Holley?i thought both sides had an equal bearing on idle mixture?
Old May 9, 2005 | 09:35 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
It's not normal. Something is blocking the passage somewhere.
Old May 9, 2005 | 01:57 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Are they both turned equal amounts?
If the driver's side is out a turn or two more than the pass. side, then you'll get that.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
89fast5oh
Sep 8, 2015 09:55 AM
IROCtometal
Sep 2, 2015 02:01 PM
