Secondaries not opening, hesitates when I floor it
Old May 24, 2005 | 03:56 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
Yeah well the choke is wired +12v and the secondaries aren't opening. The car hesitates when I floor it, timing is around 10 base timing with vac-adv on manifold. I can't tell if my timing is off, if I'm running rich/lean or what the hell is going on.
I thought carbs were supposed to be EASY
Old May 24, 2005 | 04:42 PM
Owen's Avatar
Car: 1989 Formula 350
What kind of carb? Holley? Vac secondaries? We need more information...
Old May 24, 2005 | 04:45 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
How are you verifying that the secondaries aren't opening? Driving around with the hood and air cleaner off?
Old May 24, 2005 | 04:50 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Edelbrock 1406
sorry, it was in the sig
Old May 24, 2005 | 04:51 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
I let the car warm up, and then I was pulling the throttle arm by hand quickly and they were not opening.
Old May 24, 2005 | 05:40 PM
They shouldn't open doing that. Only when the engine is under load - accelerating the vehicle.
Old May 24, 2005 | 06:09 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
hesitates with a eldy carb is common complaint, you probably are going lean on secondary throttle opening, I would look at a bigger squirter or delay or tighten the secondary opening, it could be opening too fast
Old May 24, 2005 | 06:30 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
how do I go about doing this?
Old May 24, 2005 | 06:33 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The only way to delay the secondary opening is to add weight to the counterweights on the secondary air valve.
Old May 24, 2005 | 06:50 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
I thought carbs were supposed to be simple.
Old May 24, 2005 | 06:57 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
You mentioned you can't tell if your timing is off... Why not? I imagine this isn't the source of your problem (timing), but it's usually easiest to check....
Isn't there an easy way to check if it's going lean or rich? I mean, with a q-jet you could disconnect the accelerator pump, if it's better then it was rich, if worse, lean... Right?
Old May 24, 2005 | 07:00 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No more complicated or simple than anything else. You just picked a carb that doesn't have an adjustable secondary opening, unfortunately.
Old May 24, 2005 | 08:52 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
well how do i make this thing kick ***? Im about ready to let someone else do it for me.
Old May 24, 2005 | 08:55 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
http://www.edelbrock.com/automotive/eps_intro.html
Old May 24, 2005 | 10:06 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
already been there today
plus I have that all in the booklet that came with the carb
nothing is really helping, because I dont understand whats good and what's bad
Old May 24, 2005 | 10:09 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I don't know what to say, it's all laid out there in black and white.
Old May 25, 2005 | 07:39 AM
contact's Avatar
Engine: sbc 350
Token,
I suggest:
changing the accelerator pump setting,
up and down one 'hole', and tell us what happens.
also, the choke must be completely open,
wire it open, if there is any doubt.
Hotrodboba400
Dec 10, 2019 07:07 PM
webeeZ28
Sep 14, 2015 12:00 PM
Ranbo108
Sep 9, 2015 12:20 PM
mrdevontay
Sep 2, 2015 08:04 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
