i have to pump the gas a lot for it to start??????????????
Old Jun 30, 2005 | 06:16 AM
kev2318's Avatar
Car: 85 firebird se
Transmission: auto.
when i want to start my car i have to pump it and start it at the same time. before it would start after one pump. but after it starts it has no problem starting all day its just that first start.
Old Jun 30, 2005 | 09:00 AM
jasman19's Avatar
Car: RED 1986 IROC-Z28
Engine: 350 5.7L
Transmission: TH 700R4
Axle/Gears: 3.23 10 Bolt
I would check the adjustment on your choke. If its having problems starting try richening the mixture. There should be some arrows on the choke cap that will show you which way richens and leans. If that doesn't work then check and make sure the linkage is working properly. The choke should engage if you press the gas once, if not then there may be some binding somewhere.
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
355tpipickup
Aug 13, 2015 07:35 AM
92camaroJoe
Aug 13, 2015 06:07 AM
