heat riser question
Old Jul 5, 2005 | 07:51 AM
Thomas Aquinas's Avatar
Car: 1986 Iroc
Engine: Afr 408
Transmission: T56 Magnum
Axle/Gears: Moser 9" 3.70s
heat riser question
Need some help with making a decision. I'm currently building a 383 for the street/strip. No emissions or anything the like. This will be a weekend/summer car only, no winter or bad wheather driving (which kinda limits me in ohio I know).
I'm ordering a set of AFR 195 heads that come with a heat riser. Do I really need the heat riser? I'll be using an airgap manifold and a 750 carb. If it takes a little more time for warm up, so be it. I've heard of people blocking these off? Can I order the 195's without the heat riser? Is a heat riser necessary for an "offroad"-type carb setup?
Thanks...
Old Jul 5, 2005 | 11:01 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
I have them blocked off on the 396. I've blocked them off on 350s before.
Not really needed for a summer car.
Old Jul 5, 2005 | 11:44 AM
Car: 1986 Iroc
Engine: Afr 408
Thanks for the reply,
The manifold I'm going to use blocks them off so I guess I don't need a block off plate or anything. What I'm still confused about is the path in the head. Is there a "hole" in a exhuast port that routes it back toward the manifold?
Old Jul 5, 2005 | 01:00 PM
five7kid's Avatar
Yes. Some heads require the hole to be drilled if you want that function. I've never dealt with AFR's, though.
Old Jul 13, 2005 | 11:59 AM
browncamaroz28's Avatar
Car: 1982 Camaro Z28
Engine: electric
Transmission: powerglide
Axle/Gears: 10 bolt
i have mine blocked off on my car and i drive it all year round(including snow) and i have no problem just make sure to have an electric choke if you plan to do what i do
chazman
Aug 28, 2018 03:25 PM
CRFred
Feb 7, 2016 11:39 PM
redmaroz
Aug 16, 2015 11:40 PM
kyle5647
Aug 15, 2015 11:56 PM
bamaboy0323
Aug 15, 2015 07:20 AM
