air going the wrong way through carb
Car: 1982 Camaro Z28
Engine: electric
Transmission: powerglide
Axle/Gears: 10 bolt
yes at high rpm the air is going in and out. the timing is right and its not missing on any cylinders. it is running slightly rich but not way off from the proper a/f ratios. I'm thinking that its because of my exhaust, which goes from a edelbrock shorty header to a single 3 inch collector, then through a 3 inch high flow cat, but then down to a single 2.5 inch cat back. does anyone know if the backpressure would cause this?
Car: 1983 G20 Chevy
Transmission: 4L60
Valve that is not adjust right, valve timing that is not good, could possibly just be some reversion too. Maybe the intake has a bigger runner than the heads.
Ghettobird52
Jul 5, 2024 11:18 PM
Dialed_In
Aug 20, 2015 01:45 PM
86IROC112
Aug 17, 2015 02:00 PM
