Where to get Blow Thru carbs for S/C?
Old Jul 8, 2005 | 06:45 PM
TPIMarow6.6's Avatar
Car: 85 Camaro Z-28
Engine: 6.6
Transmission: 5-speed
Where can i get a carb for my blow thru style supercharger setup? i need one 750+cfm
Old Jul 8, 2005 | 10:40 PM
Chris's 85z's Avatar
Car: 85 Z
Engine: 383
You need a Demon or a 4150 holley. Jeg's,Summit......
Old Jul 9, 2005 | 04:53 AM
blown3rdgen's Avatar
Not hard to build your own or can get one done by CSU
Matt
Old Jul 13, 2005 | 11:46 AM
browncamaroz28's Avatar
Car: 1982 Camaro Z28
Engine: electric
Transmission: powerglide
Axle/Gears: 10 bolt
im actually going to be doing a edelbrock performer blowthrough set up and from what i've found that can run about 8-9 psi without any mods. go here for reference, its about halfway down the page under carter afb carb....... http://www.vs57.com/carb.htm
oh and btw you may not need such a large carb. you have to remember you are forcing air in so flow rates change with boost, but i don't know what your set up is.
Old Jul 13, 2005 | 02:12 PM
Car: 85 Camaro Z-28
Engine: 6.6
well i am running mid 12's currently on a low comp. 406. and i am going to run a holley not a carter/edelbrock. but that is an interesting link i heard all you have to do is get solid floats and use a carb box(not a hat) and boost reference the power valves and thats basically it besides other non major mods. i heard this from summit tech when i called to ask about it.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Jerzyperson
Carburetors
Nov 13, 2015 01:07 AM
budowski
Carburetors
Oct 2, 2015 10:16 AM
Wylecoyote08
Sep 8, 2015 08:26 AM
90formulaVortec
Sep 3, 2015 09:26 AM
