Mechanical Carborator?
Old Jul 9, 2005 | 10:58 AM
Tripper511's Avatar
Car: 1982 Trans Am
Engine: 350 4BBL
Transmission: 4 Speed Manual
One of my car buff friends was telling me to get a mechanical carborator. He said that instead of using suction to open it uses mechanical means. I've never heard of it but I was wondering if anyone else has and where I could purchase one.
Old Jul 9, 2005 | 02:21 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Is he talking about a mechanical secondary carb instead of a vacuum secondary carb?
Old Jul 10, 2005 | 08:02 AM
contact's Avatar
Engine: sbc 350
perhaps this is a reference to what I
call a 'slide' carb, often used on motorcycles.
The slide can move in two ways,
venturi vacuum, or
right off the throttle - aka mechanical
Old Jul 10, 2005 | 12:51 PM
Tripper511's Avatar
Car: 1982 Trans Am
Engine: 350 4BBL
Yeah it's the mechanical secondary carb
Old Jul 10, 2005 | 01:03 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You can get them anywhere, but you'd need to replace more than just the carb to use it. In the end the gains wouldn't be that great, unless you were drag racing or something.
Old Jul 10, 2005 | 07:52 PM
Tripper511's Avatar
Car: 1982 Trans Am
Engine: 350 4BBL
Such as new intake manifold?
Old Jul 10, 2005 | 07:55 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Possibly, depends what manifold you have, and what carb you use.
A Holley 6210 would work with a stock intake, but a 4150 would not.
Old Jul 10, 2005 | 08:00 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Possibly a new manifold. Certainly a new distributor and some odds and ends to lock the TCC up without a computer.
Old Jul 11, 2005 | 07:06 PM
Air_Adam's Avatar
New dissy? didnt an '82 LG4 have a vac advance distributor?
Old Jul 12, 2005 | 11:38 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Only in Canada.
Tripper, sounds to me like your "car buff" friend is more of a magazine buff. While what he is saying is true for a drag race car, you wouldn't see any benefit on your stock engine with a properly operating stock carb on the street.
Old Jul 12, 2005 | 08:31 PM
3rd gen V8's Avatar
Car: 1992 camaro rs T-top
Engine: 305 ci V8 TBI
So it would be better to get a mech carb than a vac one when you have a very big and agressive cam?
Old Jul 12, 2005 | 10:41 PM
Air_Adam's Avatar
Not necessarily... I think what Five7 was getting at, is that on a street car, its not really worth the money and effort. Mechanical secondary carbs also don't get along with automatics as well as vacuum secondary carbs do. Big cams make the problem that much greater.
Old Jul 13, 2005 | 10:05 AM
Tripper511's Avatar
Car: 1982 Trans Am
Engine: 350 4BBL
When you say automatics do are you talking about the transmission. I have a 4 speed manual so would it have a difference?
Old Jul 13, 2005 | 01:45 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Not really, the stock Qjet is still probably a better choice for you, at least for now.
Old Jul 13, 2005 | 02:40 PM
Air_Adam's Avatar
Mechanical secondary carbs work best with manual transmissions, but if your engine isn't far from stock, then changing it won't really do you much good.
Lbibb
May 5, 2016 12:00 AM
sjorgens
Oct 1, 2015 07:54 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
mfp189
Sep 27, 2015 09:25 AM
