carb not big enough?
Old Jul 16, 2005 | 05:21 PM
firebird45331's Avatar
Car: 86 Firebird, 2002 Monte Carlo, 91 v
I have a 79 350 with 416 heads. I'm using a holley street dominator intake, comp 270-h10 cam, flowtech headers, and an edelbrock 1405 carb. Is this carb too small for my application? Would a 750 be too big or maybe a street avenger 670?
Old Jul 17, 2005 | 12:25 AM
79vette's Avatar
Car: 1979 Corvette
Engine: 355, TFS heads, comp 270H cam, 10.5 comp.
Transmission: 700r4/ 3:55 posi/ 2500 stall
Nope, 600cfm is plenty of cfms for your combo if I assume your keeping it under 6000 rpms. You will need to make sure your carb is properly tuned though and that it is getting the proper fuel pressure.
Old Jul 17, 2005 | 01:38 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
600cfm should work just fine for you.
Old Jul 20, 2005 | 09:09 PM
kyle folds's Avatar
Car: 89 Firebird
Engine: 355
Transmission: 700
I have a question on this subject.
My engine is from a 94 truck, .350 bored .030, 4 bolt, balanced, heads ported, 10/1 compression, .488 lift single pattern cam advanced 4deg.
The guy that block work told me it would take 7000 all day but I dont ever take it past 6000.
Lately I can pull strong though first gear to 6k, but every gear after that it starts running out of gas at around 3500.
Been through the 1405 carb twice and even put in bigger jets. Ran a pressure gauge in the car and it doesn't drop below 6.5 psi.
Plug read great.
Do I need a bigger carb
Old Jul 22, 2005 | 08:02 PM
kyle folds's Avatar
Car: 89 Firebird
Engine: 355
Transmission: 700
Got it. The float in the rear bowl was hanging (can't see a reason why) replaced it and everything is fine now.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
customblackbird
Oct 1, 2015 04:30 PM
WickedBowtie
Sep 11, 2015 11:24 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
rjcme
Sep 5, 2015 01:23 PM
