tbi to carb
Old Sep 5, 2005 | 06:05 PM
theMachinist's Avatar
Car: It was a 90' firebird formula
Engine: It had 357 tbi
Transmission: Was 700r4 auto
Axle/Gears: Was 2.73
tbi to carb
i currently have a 350 runnin with stock 305 tbi manifold and heads, i was thinkin of replacin that with a ported set of heads and carb but dont wanna change the fuel pump, i was just wanderin if i just put in a in-line fuel pressure regulator what the pressure would need to be for a carb or does it just depend on the type and size of the carb
Old Sep 5, 2005 | 08:30 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You need to run a return-style regulator set to 4-6 psi.
Don't use a dead-head type regulator. Your pump will hate you if you do.
Old Sep 5, 2005 | 09:03 PM
spills's Avatar
Car: 89 RS
Engine: 6.3L Megasquirted HSR
Axle/Gears: 3.70 Posi 9 bolt
What do you mean "dead-head"? Im in the process of looking for a AFPR as well. From what I remember, it as to be a 3 port return-style. Just curious what you meant by dead-head
Old Sep 5, 2005 | 10:05 PM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
By dead head he means no return. Like a river flowing up to a dam with a small hole in it. Anything after the hole finds it's way to the motor. The dam being the regulator. Tends to put more stress on the fuel pump seeing as how it was made to be used with a return style.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Wylecoyote08
Sep 8, 2015 08:26 AM
rjcme
Sep 5, 2015 01:23 PM
Billy Decker
Sep 4, 2015 03:46 PM
