engine wiring?
Old Sep 16, 2005 | 11:35 PM
af86z28's Avatar
engine wiring?
i have a 1985 z28 that had a e-qjet.i swapped in a 350 and i am trying to figure out what wire i hook up to my choke on the mechanical qjet.so which wire is it.thanks
Old Sep 17, 2005 | 02:11 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It's the same wire that was connected to the choke on the carb you removed.
Old Sep 18, 2005 | 11:10 AM
Vader's Avatar
IIRC, it should have been a green one, single spade connector.
Old Sep 19, 2005 | 11:38 PM
af86z28's Avatar
cool.if i would have removed the e-carb,i would have put it back on there.the previous owner removed it and put a busted up edelbrock on.he ran the mixture screws through the primary's,what a clown
Old Sep 19, 2005 | 11:42 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Ran the mixture screws through the primaries?
Old Sep 20, 2005 | 10:33 PM
af86z28's Avatar
yep,those two mixture screws on the front of the edelbrock carb.the primaries are the two barrels on the front?
Old Sep 21, 2005 | 12:03 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yes, but what do you mean they were "ran through"?
Old Sep 21, 2005 | 11:44 AM
af86z28's Avatar
he screwed the screws right into the primary barrels.
Old Sep 21, 2005 | 12:57 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
As in the tips of the screws are protruding through holes in the primary bores? That's what they're supposed to do.
Old Sep 23, 2005 | 05:04 PM
af86z28's Avatar
not just the tips,the whole shank of the screw.
Old Sep 25, 2005 | 10:37 AM
Vader's Avatar
Yes, yes. I know that. I know that already. I got that out of it on the first read-through.
You used the term "clown" to describe the one who did this? That was being too kind.
Are the TPS, MC, and kicker solenoid wires and connectors still intact?
Infested
May 22, 2018 11:56 PM
Caspar
Jun 19, 2016 11:19 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
