Do I need to tune the carb out of the box?
Old Sep 30, 2005 | 02:17 PM
88_Import_Slaye's Avatar
Car: 88 Camaro
Engine: 310 LG4
Transmission: 700R4 w/2200 stall
I bought an edelbrock 1406, I'm going to be starting the motor this sunday for first time (i've said this about 6 times in the past 5 months now), is there anythjing I need to do to adjust the carb? I'm about 500' above sea level. There are two screws in the front that looks like I can adjust with a philips screw driver. which is which?
Old Oct 1, 2005 | 07:13 AM
onebad84z28's Avatar
Car: 84Z28
Engine: 305,s/r torquer heads,cam,headers
Transmission: 700 r4
The carb will be close usually right out of the box to get the car running and break the cam in ,but you will need to fine tune the idle mixture screws, also i found the carb to be a little lean on my engine and need a rod and a spring change .the pump shot was also too short. Read your manual, everything you need to know is in there. they sell tunning kits get one.
Old Oct 1, 2005 | 10:09 AM
Car: 88 Camaro
Engine: 310 LG4
lol, I read the carb manual, I understood exactly 1% of it. Most of it was charts on which rods I need for this and that, but I couldnt under stand it. I need a "For Dummies" book I guess.
Azrael91966669
25
Jun 20, 2017 04:04 AM
nuggie
Aug 25, 2015 01:27 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
