Holley Info/identification needed!
Old Oct 1, 2005 | 12:45 PM
IROC-Turbo's Avatar
I have a 2 or 3 of these carbs and there are no numbers stamped on them that i can find.They bolt to a regular quad intake.Everyone ive showed them to have never seen one.Local parts stores have no info either.Thanks
Old Oct 1, 2005 | 12:46 PM
IROC-Turbo's Avatar
It didnt post the pic.nother try.
Attached Thumbnails Holley Info/identification needed!-holley-quad.jpg
Old Oct 1, 2005 | 12:47 PM
IROC-Turbo's Avatar
nother pic
Attached Thumbnails Holley Info/identification needed!-holley-quad2.jpg
Old Oct 1, 2005 | 12:48 PM
IROC-Turbo's Avatar
Last pic
Attached Thumbnails Holley Info/identification needed!-holley-quad3.jpg
Old Oct 1, 2005 | 02:26 PM
65panhed's Avatar
Car: 1984 Z28
Engine: L69 305 HO
Transmission: 5 speed manual
Axle/Gears: Auburn pro yukon 3.73 gears and axl
Carb ID
These carburetors are the old holley 4360 models. They are a Q-jet replacement for GM cars, and some Chrysler models.They flow about 450 cfm. If you need more info I have it.
Old Oct 1, 2005 | 09:05 PM
IROC-Turbo's Avatar
i finally found a set of numbers on it.6R-5610b.All the info you can give me would be great.Thanks
Old Oct 1, 2005 | 09:44 PM
65panhed's Avatar
Car: 1984 Z28
Engine: L69 305 HO
Also known as the economaster. Primary bore is 1 3/8" secondary bore is 1 7/16". 90 cc fuel bowl. Regular holley jets will not work as these jets are metric. I don't know if this unit is still produced, but I think not.
Old Oct 2, 2005 | 12:04 AM
IROC-Turbo's Avatar
How old is this thing.Dont sound too old if its metric.They still make kits for these things or are they even worth fooling with??They come factory on anything??
Old Oct 2, 2005 | 09:30 AM
65panhed's Avatar
Car: 1984 Z28
Engine: L69 305 HO
Intro to market About 75 or 76, as far as I know they were aftermarket only. I couldn't say if its worth the trouble or if they make kits for them. They might be a good carb for a V6 but that is beyond my knowledge base. If all you were concerned about was low rpm,and good off idle performance and mileage this might be for you. But I would say that for any performance use go with another carburetor of almost any brand 500 cfm or larger. By the way this carb appears to be mechanical secondaries. Good luck with your choices............Bill
Old Oct 10, 2005 | 06:21 PM
IROC-Turbo's Avatar
Appreciate the help!!I'll keep these as long as i have room anyway just for the hell of it.With the way gas prices is going i might just try it on the 305 since its no speed demon anyway.
Old Oct 11, 2005 | 10:13 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
I had forgotten all about those things. Somebody had put one on the '66 Impala 396 that I got from my in-laws. I put it on the '71 3/4 ton truck 350 I had at the time just before I sold the truck, and put its q-jet on the 396.
It is the one exception you'll find to mechanical secondary carbs being double pumpers.
IROCZ1989
Jan 24, 2016 03:55 PM
355tpipickup
Aug 19, 2015 10:02 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
