Carb Spacer
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
Carb Spacer
Im going to be putting in a 1 inch carb spacer. I was just wondering if I am going to run into any problems with these cables attached to the bracket since the carb will be higher.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You should at least check the TV cable geometry when you're finished to see if it's within acceptable limits. Why do you want to run a spacer?
Car: 83 Z-28
Engine: LG4
Yeah thats what I was worried about. My friend has a spacer that he said I could try out once I go to the track to see if it makes any difference. Do you know if they make any brackets that accommodate for the carb being higher up?
Engine: 383 Carb
Transmission: 4L60
You could try to find something that mounts to the carb instead of the intake. Chances are you'll have to fabricate something yourself.
