Emergency Help Please!!!!!
Old Nov 10, 2005 | 07:22 PM
  #51
kboehringer's Avatar
Car: 1982 - Z28
Engine: 350 / CCC Q-Jet
Transmission: THM-700R4
Axle/Gears: 10 Bolt - 3.73
Originally posted by naf
Autozone here no longer carries the real fork, at least round these parts. You have to buy the $30 scanner now.
10Gunman,
I'll check Autozone. We have a few in the area. One is open 24hrs. I'm fairly confident that I can find one for you... As I recall it was about two bucks ($2). Send me a PM with your U.S. mailing address.....I'll send it reg mail. I may not be able to get to one of the Autozones until Saturday.....Don't expect it until about Wednesday+ (unless your in Alaska or Hawaii).
Kurt
Old Nov 10, 2005 | 09:07 PM
  #52
10gunman's Avatar
Car: 85 Camaro Z-28
Engine: v8 305 4bbl carb
Transmission: t-5
kboehringer
ok cool thanks I live in Illinois I'll send u a pm.
Old Nov 13, 2005 | 09:16 PM
  #53
10gunman's Avatar
Car: 85 Camaro Z-28
Transmission: t-5
hey kurt listen I was reading and reading my posts again to see if I left something out and you are saying I woun't be able to read the codes if my car is not on? do you mean I have to turn on my car and then stick the fork in? I think last time I got a 23 code I stuck the paper clip on and then turned the key but did not turned the car on and it worked what do you guys suggest I do turn on the car and then stick the fork in that's what you're saying right? one more thing what if I stuck the fork and turned on the car is there a problem is that maybe why is not working? well let me know oh and thanks again to you and naf for the help you guys have sent me but I'm in need of more again because is still not reading sorry for the trouble.
Old Nov 14, 2005 | 08:02 AM
  #54
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Read your codes with ignition on, engine off. Doesn't matter whether you stick the fork in before or after you turn on the ignition. Just don't start the engine while reading your codes.
Old Nov 14, 2005 | 08:04 AM
  #55
Car: 1982 - Z28
They can be read with the engine running, or the engine off and the key forward. Just don't START the car with the fork in.
I usually check the codes with the engine running. Fortunately, my son's car hasn't thrown any codes for weeks. We FINALLY got it all working correctly
Old Nov 14, 2005 | 08:53 AM
  #56
8492bird's Avatar
Car: 84-92 firebirds
Engine: 2.8/3.1
Transmission: auto
You are putting the jumper into the upper row of the ALDL are'nt you? Jumper first, then turn key to ON (idiot lights on).
Old Nov 14, 2005 | 12:40 PM
  #57
10gunman's Avatar
Car: 85 Camaro Z-28
Transmission: t-5
yes guys that is what I have been doing and nothing still very weird.
Old Nov 14, 2005 | 05:56 PM
  #58
naf's Avatar
naf
Pin A on the ALDL is the top right pin and is a ground. By connecting it to Pin B (immediately to the left of A) you're providing a ground to Pin B.
You may try to ground Pin B with a jumper wire to another chassis ground.
Old Nov 14, 2005 | 08:20 PM
  #59
10gunman's Avatar
Car: 85 Camaro Z-28
Transmission: t-5
oh ok cool I'll try that then so just finding a different ground should work? cool thanks for the tip. oh by the way I failed my 2nd emissions test today but there was an improvement just by adding the air pump and emissions hoses thanks for the help for that guys I'll will let u know what is next on my agenda
Old Feb 27, 2006 | 08:27 AM
  #60
camaroracer016's Avatar
Car: 88 Camaro
Engine: 5.3
Transmission: TH350
Have any luck with the car yet?
Old Feb 27, 2006 | 12:13 PM
  #61
10gunman's Avatar
Car: 85 Camaro Z-28
Transmission: t-5
no I sold it thanks.
Vintageracer
Jan 10, 2020 05:33 PM
Warlocksirix
Sep 3, 2015 12:26 PM
smooth
Aug 18, 2015 06:34 PM
Bob88GTA
Aug 18, 2015 03:31 PM
jj4
Oct 9, 2000 01:31 PM
