4160 rebuild problems
Old Nov 15, 2005 | 08:13 PM
327???'s Avatar
Car: '82 Sport Coupe/'89 bird/'77 280z
Engine: 355/2.8/L28E(t)
Transmission: TH350/T5/4 spd
Axle/Gears: 3.73/3.42/3.54
I just rebuilt my 600 cfm 4160, before it was rebuilt if i revved the motor it would cough then rev an idle quality slowly decreased. now it still does the same thing but will also barely idle, run poorly in general , and backfire thru the carb occasionally when revved.
the timing is set at 8 deg. initial
Old Nov 15, 2005 | 09:54 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Whats the pump cam setting at?
Old Nov 16, 2005 | 02:49 PM
327???'s Avatar
i dont know how to check that, but it is a red cam and the pump lever moves as soon as the throttle is opened.
a friend said i might have a tight valve, would that cause a backfire. i just installed a new cam and the motor ran great during break-in but had that cough.
i'm gonna change the plugs and see if that helps any.
Old Nov 16, 2005 | 03:56 PM
327???'s Avatar
the plugs solved most of the problems along with uping the timing to 16 deg. i still have that little cough. i think it is mechanical advance related though.
Old Nov 16, 2005 | 07:17 PM
Karm's Avatar
re:
A backfire through the carb is a lean condition, you may need a larger pump cam. The Holley on my 396 came with the orange cam, and off idle problems untill I put on a green cam.
Old Nov 17, 2005 | 02:58 PM
327???'s Avatar
the plugs were the cause, they were pretty fouled. it doesn't backfire any more, im gonna get an advance kit and a couple of pump cams to see it i can get rid of that little cough.
Frozer!!!
Jan 19, 2024 04:55 PM
Infested
May 22, 2018 11:56 PM
someone972
Aug 30, 2015 12:52 AM
sreZ28
Aug 14, 2015 07:48 PM
hokis
Aug 9, 2015 03:57 PM
