tps voltage
Old Dec 28, 2005 | 11:28 PM
NathanC5's Avatar
Car: 84 camaro z28
Engine: '89 L98 converted to CC Quadrajet
Transmission: '89 700-R4
tps voltage
Ok, i finally checked the tps voltage on my car after reading several posts that said my surging problems could be a faulty tps sensor. my readings were 1.60 volts at idle. The voltage would go up steadily though as I opened the throttle to wot with no weak spots. How do i go about adjusting it? i have another cc qjet to experiment on before i tinker with mine. Also, the surging only occurs once the car has warmed up completely.
Old Dec 29, 2005 | 12:07 AM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
normally the voltage doesn't change unless there is a problem with the TPS or the adjustment has been messed with.
on the air horn there is a small plug by the accelerator arm, see pic. you need to remove this plug, under it is the adjustment screw, turn it clockwise to decrease the voltage, turn it
counter-clockwise to increase the voltage.
this is very important, ONLY use a left handed drill bit to remove it as the plug will probably bind on the drill bit & spin, if you don't use a left handed drill bit, you will probably run the adjustment
screw into the air horn & then you will have problems getting it back out.
if the plug doesn't turn while you drill a hole in it, use a sheet metal screw to pull it out.
i believe you will need a 1/8 inch drill bit to drill the hole in the plug. you don't need to drill very far, just enough to get a hole through the plug. don't drill it off center.
set the voltage with the motor warmed up & the choke fully open.
once you have the voltage set right, you need to put another plug in to keep the screw from turning from engine vibration.
the pic is courtesy of Vader from another post.
Old Dec 29, 2005 | 01:43 AM
Vader's Avatar
This might be clearer:
Old Dec 29, 2005 | 05:28 PM
NathanC5's Avatar
Car: 84 camaro z28
so where do i get another plug? and where do i find a left handed drill bit? is the plug the little circle that is on the accelerator arm or is it somewhere else?
Old Dec 30, 2005 | 02:33 AM
DENN_SHAH's Avatar
the pic i posted only shows the location of where the plug is at, the plug is number 19 in the pic Vader posted.
i wish i had that pic before, thanks Vader
i don't know if you can find a new plug by itself, they come in carb overhaul kits.
its unlikely they will have one, but you may ask at a auto repair shop if they have a spare.
a parts house or hardware store should have the left handed drill bit.
Old Dec 30, 2005 | 11:20 AM
Vader's Avatar
A little dab of RTV/Gasket maker in the hole should prevent contamination and tampering, and is easier to dig out next time.
Old Dec 30, 2005 | 06:20 PM
NathanC5's Avatar
Car: 84 camaro z28
i have one last question. how far do i drill before i put the screw in to pull out the plug
Old Dec 30, 2005 | 08:09 PM
DENN_SHAH's Avatar
not very far, the top of the plug is about as thick as the rim on top of a coke can once you get through the plug you will probably notice a slight drop or jump of the drill just as it gets all the way through the plug.
if it works the way it does for me almost everytime, the left handed drill bit will bind up in the plug & un-screw the adjustment screw & will push the plug up out of the air horn so you can pull it off with some pliers.
Old Dec 31, 2005 | 04:55 PM
NathanC5's Avatar
Car: 84 camaro z28
i guess i was looking at the picture all wrong. i was drilling on top. after a while i looked to the side and the whole was already there. no amount of screwing or unscrewing the hex brought the voltage to under 1.8. it would increase if i went counterclockwise, but clockwise would produce nothing. guess i have to change the sensor.
BumpaD82
Feb 26, 2016 02:57 PM
HoosierinWA
Oct 7, 2015 10:15 AM
racereese
Oct 3, 2015 03:46 PM
327IROC85
Sep 23, 2015 12:11 AM
