ECM mods for the #1228079 and CCC Q-jet
Old Jan 7, 2006 | 03:05 PM
rodsss's Avatar
Car: 1987 Monte CarloSS
Engine: Tweaked 305
Transmission: Tweaked 200r4
I've been experimenting with some DIY electronic mods to my VAC sensor voltage to compensate for loss of vacuum after installing a performance street cam in my 305 Monte SS...217/223 @.050" 112LSA & .502 lift. So far everything is great and it cured my TCC lockup issues too!! I'm wondering why there are no topics on modifying the codes on these ECM driven Q-jet carbs. I'm working the DIY modifications using basic Radioshack parts, but I like to know more about the actual code and how it drives the Q-jet. From studing the EFI topics it seems that the only physical difference is going from a Mixture Control Solinoid to an Injector.
Anyone else doing DIY electronic mods? Checkout http://www.siliconchip.com.au
or
http://www.jaycarelectronics.com/index.asp
Old Jan 7, 2006 | 03:19 PM
Vader's Avatar
Have you searched the DIY/PROM Board? There have been at least a few discussions about CCC ECM applications there. It appears that there may be some support for the 1985-up CCC ECMs. For the earlier ECMs, there doesn't seem to be much.
Old Sep 21, 2006 | 02:37 PM
Vader's Avatar
Any luck tracking down information?
Old Sep 23, 2006 | 01:08 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Craig Moates' site has a .ECU file and some .BIN files for the L69 and ZZ4 engines with the later model ECMs. I have several files that I have saved, due to the fact that my 1988 Cadillac Sedan Deville Brougham has a 403 in place of the 307 and still has the stock ECM with a modified E4ME Q-Jet. When I ever have time to dig it out and rebuild the 403, I might play around with it a little bit. The cam in the 403 was something around 225/225, but I don't have the specs in front of me right now.
Elephantismo
Feb 13, 2019 12:51 AM
69GTOby
Apr 18, 2016 02:34 PM
skeltor
Feb 2, 2016 10:37 AM
customblackbird
Oct 1, 2015 04:30 PM
89bird2.8
Sep 22, 2015 05:28 PM
