hood clearance
Car: c1500
Transmission: 5speed
hood clearance
anyone have problems with hood clearence after installing a performer rpm intake and a holley in a z28, It all fits but the aircleaner what do i do without buying a hood...any suggestions
Transmission: 4L80E/4L80E
Welcome aboard.
Your easiest choice would be a drop-base open element air cleaner.
Ah, I see you specified "Z28" in the original post.
https://www.thirdgen.org/techbb2/sho...hreadid=318843
One guy went with a 2" element.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I had to use a drop-base cleaner housing, sitting on top of a 1/2 inch spacer, and change to a 2 1/2 inch element to get my Performer RPM and EDL1406 to fit under my stock RS hood.
The drop base cleaner needed the spacer to clear the electric choke on the carb, which raised the whole assembly too high, thus the 2 1/2 element to bring it back down.
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
