Power piston setting
Old Feb 17, 2006 | 10:40 AM
Tony78_280z's Avatar
Car: 78 Datsun 280z with GM 350
Engine: Carbed TBI (Truck) 350 W/Ported 193s
Axle/Gears: Stock 280Z Rear
I recently rebuilt my quadrajet, but I didn't make a note of how many turns out my power piston was before removal. What would be a good setting to start off at.
Old Feb 17, 2006 | 12:56 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
you could tighten it, then back it off 2.5 turns. I think that's a spec somewhere, but that's not at all what i'd recommend.
I think you should read this, for the best way to modify it.
https://webdisk.ucalgary.ca/~jmknopp...owerPiston.doc
edit: not sure if this is just specific to non-cc q-jets, I forget what the cc-qjet was like, the one time I took one apart...
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Bert87
Aug 23, 2015 03:50 PM
LT1Formula
Aug 20, 2015 09:36 PM
