Need help finding my QJet mixture screw
Car: 83 Trans-Am (Recarro)
Engine: 305 4bbl
Transmission: 5 speed manual
I cant find it. Any one got a image of where its at. or can discribe where its at on the carb.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
below the right red arrow is one of them. The other one is to the left of that 2" or so, can't see it in this picture. You'll probably need a funky little carb adjusting tool to turn the screws. they're spring loaded too.
Car: 2000 BMW M5
An 83 T/A should have a CCC feedback carb. It is not just the idle screws that control mixture, but also a mixture solenoid that is computer controlled, based on O2 feedback. There are specific instructions for accessing and adjusting the air bleed to get the mixture solenoid dwell correct. If you don't even know where your idle screws are I would suggest having someone who is familiar with CCC qjets do it. You will need a dwell meter set on the V6 setting.
Car: 84 WS6 Trans AM
Engine: 355ci Chevy
Axle/Gears: 3.73 limited slip
That picture looks just like my car after i junked the CC Carb because i could not get the original 5.0 stuff to work with the 5.7. If yours is origanal CC Q-jet the computer has alot to do with the mixture. I just went with a regular edelbrock Q-jet replacement.
I doubt the 83 has a CC carb. I have an 85 Z28 with just a plain factory Q-Jet.
As far as those idle screws, they usually "capped" fromt he factory. You have to drill or break the casting in the spot of the screws to reach the head.
Transmission: 4L80E/4L80E
Canadian delivery = non-CC carb.
US delivery = CC carb.
Engine: 355ci Chevy
Car: 1985 Camaro Z/28
Engine: L69
Axle/Gears: One-Wheel-WOnder 3.08
If your CC carb is running too rich, messing with the mixture screws will only make is worse. GM sealed those screws away for a reason- the mixture control solenoid(MCS) and oxygen sensor do alot of the mixing on this particular carb. Find the real problem- dono't waste your time knowing out the seals on the mixture screws just to find you didn't have fix the problem.
Car: 91 Z28 24th Anniversary
Axle/Gears: Posi 3.23
the M/C solonoid adjustments are for cruise RPM to get 35 to 45 degrees of dwell. Not an idle adjustment. After adjusting the solonoid, the idle mixture screws are adjusted to get 35 to 45 degrees of dwell at idle.
theshackle
Sep 17, 2020 08:26 AM
