Can someone take digital picture or scan of 1983 305 LG4 underhood emissions label??
Old Feb 25, 2006 | 04:28 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Hi guys, I am equipping a 1983 Firebird, previously V6, with a TPI 305 retrofitted as an LG4, complete with all emissions equipment and CCC Qjet. Can someone get me a high quality digital photo, or a scan, of the underhood emissions tag from a 1983 305 4 barrel LG4 car? I am going to have the car smogged in Virginia, and when they pop the hood to check displacement and emissions equip visual I want the label with the correct displacement and routing displayed. Thanks!
Old Feb 25, 2006 | 11:04 PM
Vader's Avatar
Do you mean something like this? What do you want it to say?
Attached Thumbnails Can someone take digital picture or scan of 1983 305 LG4 underhood emissions label??-ccjlabel1.jpg
Old Feb 25, 2006 | 11:51 PM
Car: 2000 BMW M5
Vader, that's exactly what I mean. I don't need it to say anything special, I just want the correct displacement and emissions control diagram in case an inspection station ever needs to refer to it. Is that tag for a 1983 LG4 F- car? I'm curious why the computer controlled dist. has a vac. advance line on the diagram (it calls it vac. retard). I am using a 1985+ CCC dist that does not have any vac lines on it, I wonder if I need to get the 83 one.
Old Feb 26, 2006 | 04:58 PM
rideon1200's Avatar
On Probation
Car: 2002 Formula
Engine: 5.7 LS1
The only problem I see is they don't smog in Virginia. Its a visual check. Don't give them any ideas.
Old Feb 26, 2006 | 06:58 PM
Car: 2000 BMW M5
They don't smog in VA? Oh you're kidding me. I have never lived there before (will soon though) so I didn't know that. AAAAGH I just went to tons of hassle to get every tiny little piece of emissions equipment for a 1983 LG4/L69 because I was terrified of not passing emissions the first time. Well it will certainly look stock because it will be stock for an 83 V8 now. Thanks for the heads up.
Old Feb 27, 2006 | 12:47 AM
Vader's Avatar
Actually, that was a custom for a 1982 car (I just changed the date for this example). The '82 had a mechanical advance distributor with a vacuum advance added - At least this particular one did. I'll bet the inspectors down in Tennessee are still scratching their heads.
Old Feb 27, 2006 | 01:04 AM
Vader's Avatar
Maybe this would work better for you? It lets you run a 454 with a QuadraJet in a 2006 vehicle:
Attached Thumbnails Can someone take digital picture or scan of 1983 305 LG4 underhood emissions label??-caslabel.jpg
Old Mar 2, 2006 | 05:23 PM
chesterfield's Avatar
Car: Pontiac
Vader, where'd you get these labels? Is there a site to download them?
I noticed there is a gm part number. Anyone ever order one from gm? Does anyone know where to get replacements?
Old Mar 3, 2006 | 03:48 PM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
Before we shotgun this any further. Here are the 1983 LG4 emissions stickers...
Attached Thumbnails Can someone take digital picture or scan of 1983 305 LG4 underhood emissions label??-lg4-e-sticker.jpg
Old Mar 3, 2006 | 03:50 PM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
other one...
Attached Thumbnails Can someone take digital picture or scan of 1983 305 LG4 underhood emissions label??-lg4-routingsticker.jpg
Old Mar 5, 2006 | 02:37 AM
Vader's Avatar
Thanks for the clarification. Is this closer/cleaner?
Old Mar 5, 2006 | 11:38 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Only thing i can see is the "Check valve" on the air management system is not on mine, and LG4 doesn't have a dual snorkel.
Old Mar 6, 2006 | 03:26 AM
Vader's Avatar
I caught the air cleaner difference when I altered the label. If it were mine, I'd find an intact unit or manufacture a dual snorkel cleaner from a scrap air cleaner inlet with Thermac valve.
I believe the check valve was intended to hold the AIR valve in the divert position at WOT. That was later changed to go to port at WOT/open loop to reduce emissions, but I think it also overheats the exhaust unnecessarily. Obviously, the final product would match the specifics of the application. It is supposed to be a custom replacement, after all.
Old Mar 6, 2006 | 07:20 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
I agree. I added a factory Dual Snorkel to my LG4.
TheJoeY88
Dec 31, 2016 07:30 PM
theurge
Aug 21, 2015 12:46 PM
NufNuffZ28
Aug 14, 2015 09:12 AM
Sanjay
Aug 12, 2015 03:41 PM
Street Lethal
Aug 12, 2015 11:33 AM
