What did I do wrong with my carb rebuild.
Old Mar 1, 2006 | 12:05 AM
Tony78_280z's Avatar
Car: 78 Datsun 280z with GM 350
Engine: Carbed TBI (Truck) 350 W/Ported 193s
Axle/Gears: Stock 280Z Rear
I rebuilt a Qjet carb here recently. And tested it for the first time on the car today. It revved real good. And I loved the way it "felt" on the motor.
But twice it got hung up and stayed revved. Once while In drive. The motor was still pushing with my front tires locked up in braking at a stop sign. All outside linckage was fine, I could see nothing on the outside of the carb that would make the throttle stick open. And as far as I could tell, The throttle blades were closing all the way. Looking into the top of the carb, the rear blutterflies were closed all the way too. Any ideas?
I had the holley in the back seat, changed it out at the stop sign, and went on about my buisiness.
Old Mar 1, 2006 | 12:08 AM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Must have been a long stoplight?
Old Mar 1, 2006 | 07:08 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Choke or choke linkage sticking, choke wire loose, no power or not connected (was choke open completely when this occured?), vaccuum leak, throttle return spring weak, throttle linkage binding.
I'd look at the choke first.
Old Mar 1, 2006 | 10:40 AM
It was a stop sign, so there was no time limit. It took less than 5 minutes for the two of us to change carbs.
I left the choke off, as I dont intened to use one. Is this it? Is there some internal mechanism the choke controls that, if left off, could cause that to happen?
Old Mar 1, 2006 | 10:54 AM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
I would also think choke. How high was it trying to rev?
And by 'left off' do you mean you just took the plate off, or did you remove the fast idle cam and all the associated linkages beside the thermostat?
Old Mar 1, 2006 | 11:13 AM
naf's Avatar
naf
Fast idle cam could be hanging loose and randomly engaging?
Old Mar 1, 2006 | 02:32 PM
I left off all the stuff on that side of the carb, choke and fast idle cam. I plugged the associated vacuum lines.
I'd say it hit 3500-4500 rpm. I don't have a tach.
Fast idle cam hanging loose and randomly engaging? That sounds good, give me more info...
Old Mar 1, 2006 | 02:46 PM
naf's Avatar
naf
If you've taken everything off, there should be nothing left to hang up. Take a photo of whats left and post it if you can.
May want to take a photo of the throttle linkage side too. Chance of a hang up there?
Old Mar 1, 2006 | 11:05 PM
http://www.angelfire.com/clone2/tony/Qjet.htm
Old Mar 1, 2006 | 11:12 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
hmm, those images are hosted by angelfire alright...
Old Mar 1, 2006 | 11:14 PM
Sorry again, modified links.
Old Mar 2, 2006 | 06:42 AM
naf's Avatar
naf
Everything looks clean. My guess would be throttle cable bind or weak return springs? Maybe Sonix will chime in with an idea.
Old Mar 2, 2006 | 11:03 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Also check throttle body to main body gasket alignment.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Dyno Don
Jan 24, 2016 08:24 AM
Wylecoyote08
Sep 8, 2015 08:26 AM
rjcme
Sep 5, 2015 01:23 PM
greenyone
Sep 2, 2015 03:39 PM
