Gas Mileage Ques.
Old Mar 11, 2006 | 03:58 PM
88 Z28 Guy's Avatar
Car: 1989 IROC
Axle/Gears: 3.42 Auburn
Gas Mileage Ques.
About what kind of MPG will i get with a 350 with a mild cam, a holley 4160 4 barrel carb, T5 Trans, and a 3.42 Rear Gear. Just woundering what kinda MPG do other people get.
Old Mar 13, 2006 | 09:27 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
Well not to much since you manage to get less than 20 with a stock 4 banger.
Old Mar 14, 2006 | 12:36 AM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Holleys are gas mileage hogs. The 4160s have bleeds sized to intentionally be too rich no matter what, because according to the folks at Holley, this way amateur tuner's can't make the carb so lean that it will burn up the motor. They work well for WOT at the strip but will definitely be a lot less efficient at cruise on the street than a Qjet or an Eddie/Carter 600. I'd say you will see 15-20 mpg highway with that setup, 10-15 around town.
Old Mar 24, 2006 | 09:27 PM
eXesiv|83ta's Avatar
Car: 1983 Pontiac Trans AM
Engine: 355 chevy
Transmission: 700R4 Built
Axle/Gears: Built 10 bolt 3.73 gears
It all depends on your tune. Chevy High Performance had an article recently where they had a fast camaro (556 hp, 512 lb ft) equiped with a holley and they knocked down 21 mpg on the way to the track. Search the article. The article was called tune your carb like EFI. Its in the jan 06 issue.
Old Mar 24, 2006 | 09:44 PM
7plagues's Avatar
Car: 92 Precision Red Firebird
Engine: v6->357 vortec xe262h rpm intake
Transmission: t5-> t56
Axle/Gears: 10bolt 3.42s
i get 25mpg freeway, with a halfway decent tune.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
KCG
Jun 24, 2020 04:33 AM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
Glowsock
Sep 11, 2015 11:09 PM
