Rochester Quadrajet info
Car: 82 camaro berlinetta/87 sport coupe
Engine: 87 LG4 305
Transmission: world 5speed
i'm looking to buy a new rochester qjet. but i need info on them like whats the cfm, so on and so forth. i have an 1982 camaro berlinetta. not yet but its going to have an 305 in it. just need a little bit of info, thanks
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
The CFM is "what's needed". The primaries are small and can feed anything from a V6 to a 454. The secondaries are huge but flow is regulated by a spring-loaded air valve that only opens as much as the engine needs. Max is typically 750-800 CFM (larger are available but certainly not needed on a 305).
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
Go to EBAY and search for quadrajet. There's a guy that sells them for vehicle and marine applications. Their totally gone through with a bunch of inprovements made. For instance, on the bottom of the QJET there are some screw holes that leak fuel into the manifold, the fix is to epoxy the screws. He's done things like that. Mine arrived and the carb looked like it was factory from GM!!! He has all types, CCC, electric choke vacuum choke etc. I bought my CCC 700 cfm (Computer Controlled Carburator) for $325. I literally bolted it to the manifold, hooked up the fuel line and throttle and started driving. Idle, mixture, everything set and ready.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
or you can go to the JY and pick one up for $30, maybe rebuild it with a kit for $40, and be in $70 and have an ugly yet functional carb.
why isn't there a carb on the engine now? you buying one without the induction?
Car: 1984 Z28
Transmission: auto w/overdrive
Rochester Quad
Hi,
I just bought a new carb for my 84, 305 at Autozone. They had it on sale 2 weeks ago for $229.00. I was an easy replacement with minor adjustments once installed. Plus I gained about 30 extra horsepower from before
Judi
Judi
Engine: 87 LG4 305
what is JY?
3rdgenparts
05-21-2016 11:50 PM
Linson
10-01-2015 09:50 PM
