TBI to Carb
Old Apr 7, 2006 | 04:49 PM
r0nin89's Avatar
Car: 1987 Chevy Stepside
Engine: 350 TBI w/ a Cam
Transmission: 3 Speed Stick w/ granny low
TBI to Carb
I have an 88 RS. I'm looking to eliminate all the computer I can. What does it take to convert to a carb? Anyone done it?
Old Apr 7, 2006 | 05:14 PM
Nebu's Avatar
Car: 91' Camaro
Engine: Carbed 305
Transmission: 5-Speed Manual
install a non cc distributor, different intake, fuel lines+regulator and some minor stuff like throttle linkage etc.
or just use the searchfunction to get about 179 tbi to carb threads
nebu
Old Apr 7, 2006 | 06:33 PM
r0nin89's Avatar
worth it?/price estimate
Old Apr 7, 2006 | 08:22 PM
stroker_SS's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
If your going to further modify your engine, it may ease tunability. But the carb alone might net +10-15 hp(maybe) and will likely give you less fuel econ.
Old Apr 8, 2006 | 03:18 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Brand new parts (assuming non-cc)
Carb $300, Intake $150, FPR $90, TC Lockup $90, HEI Dizzy & Coil $175 Misc $150
(Misc includes carb studs, gaskets, sealants, tranny fluid, vacuum lines, throttle brackets/linkage, fuel lines, etc. - all the $10 you-to-death goodies)
Almost $1000 total - No wonder I'm broke!
Old Apr 8, 2006 | 08:46 PM
Damon's Avatar
There is a tech article on this board on exactly how to do it. Follow it's instructions. I did it to my 92 RS when I dropped a mild 350 carbureted motor into it. For me it was definitely worth it- I run mid-low 13s with the new motor. If you're just tearing off the TBI system to replace it with a carb, no other changes, it might not be what you want to do.
What are your goals? Why are you considering it to begin with?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Wylecoyote08
Sep 8, 2015 08:26 AM
rjcme
Sep 5, 2015 01:23 PM
Billy Decker
Sep 4, 2015 03:46 PM
