What Carburetor
Car: 1985 Z-28 2003 chevy Silverado Z71
Engine: was 305 LG4 now 355 HO
Transmission: TH700r4
Axle/Gears: posi 373
What Carburetor
I have 1985 Z-28 just but a new 355 in it bulit jet hot headers 300 ish HP im useing the stock Q-Jet came off the LG4 i want a new Elderbrock Carb not sure what i need my Intake Manifold is a Elderbrock RPM thanks.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
you have an edelbrock RPM intake, and you're using the stock cc q-jet? Then that's probably a spreadbore style intake, unless you've got an adapter.
Is there a problem with the stock q-jet? I don't think you'd gain much going to a new edelbrock.
yeah i have a plate for it well i dont know some time when i 1st start it up it rev's from like 700 rpm to 1,500 rpms when i hit the gas it goes back down after that 1st time it's fine
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
Let me put my flame suit on first
ok....holley/demon carbs if you don't have to worry about emissions. All you are gonna get from a CC q-jet is passing emissions and a little more mpg.
ok....holley/demon carbs if you don't have to worry about emissions. All you are gonna get from a CC q-jet is passing emissions and a little more mpg. Thread Starter
I dont care about getting a Q-Jet really just looking for what is best and i lke edelbrock just not sure what edelbrock carb will fit my motor or best for me and the edelbrock RPM i got on it.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
From what I read, a 600 cfm ought to feed it enough, but wait for more words from the experts. If they say it's enough, the Edelbrock EDL-1405 can be had brand new at Pep Boys for $249 with a $20 rebate, and the 1406 can be had for $279 with $20 rebate (the 1406 has electric choke, but it can also be added later to the 1405 for about $60).
If they say a 750, Pep boys again has the EDL 1407 for $279 (manual choke) with same $20 rebate (and the same $60 electric choke kit will attach). Rebates good until May sometime - check out their ads. If you don't have a Pep Boys anywhere close, other stores aren't much more - but Pep Boys has the deal right now because of the rebates.
Car: 1985 Camaro Z/28
Engine: L69
Axle/Gears: One-Wheel-WOnder 3.08
Why not use the q-jet? It's rated at like 750 CFM which is plenty for your car. With a little jetting, rods, and adjustment of the air valve, it should perform great and save you a little gas $$.
Car: 2000 BMW M5
600 CFMS is definitely on the low side for a 355 if you are going to rev it at all. I ran the Edelbrock 750 on my 327 before I went EFI on it. I switched down to a 600 and lost ET and MPH, the 750 was definitely needed since I spin 6500+ rpms.
WhteRbt
Sep 21, 2015 09:48 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
