won't start Help!!!
Old May 5, 2006 | 02:13 PM
berlincam86's Avatar
Car: 1992 Z28
Engine: 350 tpi
Transmission: 4L60
won't start Help!!!
Ok I had it running for awhile after I rebuilt the carb I had to keep on the pedal to keep it running so I let it stall then I had to go do something else then I went back to start it again and it will crank but it won't start now. What could be wrong with the carb? It's a quadrajet computer controlled. I have spark and the timing is right. Its gotta be something in the carb I tried to adjust the float but that didn't help. Please help!!
P.S does anyone have one of them on the car float height tools if so how long is it so I can make one. Thanks
Old May 5, 2006 | 05:34 PM
85cmroz28's Avatar
Car: 1985 Camaro Z/28
Engine: L69
Axle/Gears: One-Wheel-WOnder 3.08
Make sure you didn't flood it. Hold the gas all the way down and crank it. See what happens.
Old May 5, 2006 | 08:24 PM
Car: 1992 Z28
Engine: 350 tpi
Transmission: 4L60
Tried it still the same. Would low tps voltage cause a no start I measured it and it was like 65 millivolts and i don't have the tool right now to adjust it. I know it's suppose to be .40 or .48 volts not millivolts. would this really cause a no start or just a rough running engine? Also, I have two differant recomended voltages I have .40 in the chiltons manual and .48 in the rochester carb manual. which one should I follow?
Derick15
Sep 17, 2016 05:28 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
EFR2000
Aug 18, 2015 08:54 PM
