Running rich
Old May 5, 2006 | 09:40 PM
ino's Avatar
ino
Car: 87 firebird
Running rich
Does anyone know how to adjust q-jet on 87 305 lg4? Just moved choke counter clockwise and seemed to help but still running rich. car does not idle at 1500 at cold starts either
Old May 6, 2006 | 12:23 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
initially i'd want to say, get a buddy to start it up cold and watch the carb, see if choke snaps shut on initial accelerator tap, then opens slightly when fired up. Then make sure fast idle cam is up. Possibly replace choke thermostat if it's not helping while adjusting.
however! Knowledge is power, see if you can get anything from these
This has a blow up picture:
https://www.thirdgen.org/forums/carb...ighlight=choke
fast idle question:
eliminating bog etc:
here's a GOOD one:
save the best for last:
ps. what does the car idle at on cold starts? too low?
Old May 12, 2006 | 07:18 AM
ino's Avatar
ino
Car: 87 firebird
thanks will try a few and yes real low 750 on cold starts and idle all the time. sometimes i have to screw in on idle screw on side to raise it. idle falls on its own sometimes when i dont run the car for a day or two.
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
tmellott89
Aug 16, 2015 02:58 PM
squiggy2
Aug 9, 2015 09:30 PM
