Figuring out what size carb i will need.
Car: 84 z28
Engine: older 350, details unknown
Transmission: th350
Axle/Gears: factory limited slip
I am thinking of getting a new carb for my 84 camaro but im not sure which one to get. It has an engine out of a 67 in it, but thats about all i know about the motor. How would i figure out which size carb i would need
Car: 84 z28
Transmission: th350
It has a rebuilt 350 from a 67. I know that it at least has an aftermarket intake and headers. IM not sure what kind of a cam it has in it, i know it gets about 5 miles to the gallon if im lucky. it burns through a full tank of gas every 2 hours or so of just idling. im looking for about 300 hp out of it plus a small shot of nitrous. is that enough info?
the cid helps. What about things like rpm range, auto or manual, single or dual plane intake, etc.
I would guess 600cfm w/ vacuum secondary for you.
BTW, you gotta work on that mpg. That is way way off, but that will come with tuning.
Matt
Matt
Transmission: 4L80E/4L80E
Something tells me you have a very bad mix of 1984 and 1967 parts.
The carb is most likely not the root of the problem.
Car: 84 z28
Transmission: th350
how would i even start to troubleshoot it. i know there might be some issues with the way he setup the charging system because of the differences between the voltage regulators, but othere than that thats all i know about the swap
Car: '68 corvette '73 Corvette
Engine: 427 454
Transmission: TH400
my 86 4x4 sierra with big tires and a 350 gets 12.
i would check for a fuel leak.
i am putting al. heads 190cc and a comp cam 274 on my camaro and i am going to use either a holley 670 or 700 vac. secondaries. i would also say a 600cfm would be plenty.
toronto formula
Nov 10, 2015 06:17 AM
knight72
Aug 10, 2015 09:32 PM
