probably an easy one
Old May 24, 2006 | 02:55 PM
allsound's Avatar
Car: 1987 Camaro Z28
Engine: 305 carb for now
Transmission: 5 speed
What should I look at first, when I rev from under the hood I can't get my secondaries to open up let alone even budge unless I open it myself. I can't seem to find anything within here of similar problems except that my accelerator pump may need to be adjusted. Does anyone else have any suggestions as I keep looking??
Old May 24, 2006 | 03:04 PM
hotrodhed120's Avatar
Car: '83 chevy camaro sc t-tops
Engine: 350 sb .03 over
Transmission: t-5 five-speed
Axle/Gears: stock axels 3.73 and mini spool
normally you won't be able to see your secondaries open by snapping the throttle. the opening is based on load and revving your car in neutral it has very little load. what type of carb?
Old May 24, 2006 | 03:36 PM
allsound's Avatar
I believe its a 4 bbl quadrajet 600 cfm, but I'm not 100% I'll have to double check the serial number off of it.
Old May 26, 2006 | 01:09 PM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
No such thing as a 600cfm QJet. They were only available in 750cfm and 800cfm models.
Old May 26, 2006 | 06:04 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
suggestions for what?
are you actually having a problem?
your secondary throttle blades, will open if you twist the throttle by hand, but not your secondary air valve. Unless your secondary lockout tab is locking your secondary throttle blades, normal when the car is off, or cold.
So don't sweat it.
Old May 29, 2006 | 09:18 AM
allsound's Avatar
yes, the problem which I should have stated before is that there is no power. I can start it and have it idel fine, and even have it drive semi normal, but it just doesn't seem to have any real power. Or at least, when I compare it to my other smaller cars with smaller engines (as this is the only 8 that I've ever had.)
armybyrd
Sep 28, 2023 12:16 AM
FormulasOnly
Jul 23, 2018 08:47 AM
Gunner242
Dec 25, 2015 04:49 PM
92projectcamaro
Dec 8, 2015 12:25 AM
3.8TransAM
Oct 1, 2015 07:47 PM
