Any advantage of spreadbore over square bore?
Car: '86 Camaro SC
I'm running an Edelbrock Performer intake, and it's spreadbore. I've always wondered this, but never really thought to ask, what exactly is the benefit of once over the other? Or is one kinds better suited for a certain application?
-Thanks, Brandon
-Thanks, Brandon
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Personally in my opinion a spread bore would be better for a daily driver that has fuel economy in mind. because you can cruise on the small primarys but when you nail it you have the huge seconadarys to get ya moving in a hurry.
Car: 90 RS/90 Z-71/73 Vega
Engine: 3.1/5.7 TBI/5.7
Transmission: 700R4/700R4/350turbo
Axle/Gears: 3.23/3.42/3.42
yup,those Q-jets sound good when you open them secondaries up..Small primarys for cruising/daily driving.The secondaries can be adjusted to open quicker very tuneable carb. Joined: Mar 2000
Transmission: 4L80E/4L80E
Squarebore. You asked why anyone would go with a squarebore.
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Squarebore is more of a performance orientated system, like said above it tends to have better fuel distribution which is nice to have if your tuning to get them last few milliseconds off your ET's!
Their is absolutely nothing wrong with using spreadbore carbs for street cars, heck a properly set up Q-Jet can support alot of power!
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
Personaly, I've always prefered the squarebore for better part throttle performance on the street. With a spreadbore, as soon as you tromp the peddel everyone knows what your up to (wwwooooaaaah).
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Car: Only a daily driver, but comin home
Engine: I have one that runs ;)
Transmission: Caged hamster that runs really fast
Axle/Gears: They are round, I know that much
Spreadbores do have that neat sound when they open up, but it all depends on the direction you are going with the engine/car. I don't care about economy so I have a squarebore, but if I was building a cruiser, I would of wanted a spreadbore.
So take into consideration what you want to do with the car and how you drive it, and decide from there. Worse comes to worse, you can buy an adapter plate for your intake to go from either style carb to the other.
Good Luck!
Good Luck!
Originally Posted by '86 350
I'm running an Edelbrock Performer intake...
Re: Any advantage of spreadbore over square bore?
I have a 73 Nova, but I plan to put a Edelbrock Performer RPM intake in it and get a new carb maybe. I plan to take it racing, but I was wondering because I am going to drive it too. So, should I go with the squarebore or spreadbore? And I want to have a nice idle so peopel know what's up lol...I'm wondering would I still get that nice souding idle with a squardbore? And I was reading that the spreadbore gives better gas economy, is it a noticable over the squardbore?
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
Spreadbore for sure. It`s matched to the manifold and no need for an adapter that you have to use with the squarebore. The adapter causes a small performance drop in my experience and according to the dyno tests I have seen(old Super Chevy articles). I`ve used both on a variety of sbc`s with 350+ hp in Vetts, 1/2 ton pick up and El Caminos. I always got better milage and performance with the spreadbore.
Thank you, Jim. I do that also I was reading that you get the most torque when you use a an aftermarket cam. Is that true? If so, what kind should I get? I have a 350 and I plan on getting a new exhaust and headers too. Also, what size carb should I get? I know that I want a 4bbl carb through.
sreZ28
Oct 22, 2015 08:21 AM
adapt, adapter, bore, carb, carburetor, gen, holley, sbc, spread, spreadbore, spreas, square, squarebore, versus, vs
