Fuel Pump Overheating.
Old Jun 28, 2006 | 07:16 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
I have a holley red on my car. It will run for about 10-15 mins b4 the pump overheats and shuts off. Do i need to get a return style regulator so i can cycle more fuel through it to keep the temp down, or is there another way?
Old Jun 28, 2006 | 07:29 PM
ZEEYAA's Avatar
Car: 1991 Z-28
Engine: 383 / TPIS MINI RAM
Transmission: 700-R4
Axle/Gears: MOSER 9IN 3.89
I have always for some reason seemed to have problems with the Holley blue/red pumps, but yet others have run them for years. That may help to do a return line but if it were me I would save up and get an AEROMOTIVE unit, its the best thing I have done for my fuel system. Are you sure you have the right gauge wire run to the unit and it is grounded properly? One of the biggest killers for electric motors is heat and thats what they generate when the motor is not getting enough current. The next time it starts slowing down put a meter on it and see what the amp draw and voltage drop is. If you pulling power from a pretty long distance for the pump you may have enough voltage drop to cause a problem, so you may have a simple fix and just up the wire size to like maybe a #10 ga.
Old Jun 28, 2006 | 07:42 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
Well i use the same size wire that was coming from the pump, its like 14 guage or something. Would it be ok to run 10 guage from the switch to the pump and then the little 2 inches of 14 guage that goes into the pump.
Old Jun 28, 2006 | 07:59 PM
ZEEYAA's Avatar
Car: 1991 Z-28
Did you check to see if you had a voltage drop? Anyway it never hurts to oversize the wire. Also it would be a good idea to put an inline fuse for the correct amperage that the pump calls for. When you do the wire upgrade and you butt splice to the pump wire your connector will be to big, so just take and strip the pump wire about twice as long, and fold it into to make it bigger so the butt splice will make a good crimp on the wire, I think the wire on the pump is 16/14 also. Remember if its any distance you get a voltage drop, so and upsize on the wire will actually help with the voltage drop.
Old Jun 28, 2006 | 08:13 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
Well i am not by my car now but when i get back to it i will check. Thx for your input.
Old Jun 28, 2006 | 08:19 PM
ZEEYAA's Avatar
Car: 1991 Z-28
Not a problem, let me know how it works out. I will check back later.
Old Jun 28, 2006 | 08:40 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Upgrading the wire as posted will help the pump run better, but you should also run a return style regulator. I ran a blue pump on another car, and could hear the difference in how much better the pump ran after upgrading to a return style regulator, especially after a long trip (30 min or longer).
Are you running 12V through a switch directly to the pump, or using a relay? If you're not using a relay I'd definitely add one.
Old Jun 28, 2006 | 09:18 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
Well i am running 12v through a switch with a 7.5 amp inline fuse.
Old Jun 29, 2006 | 07:44 AM
Lo-tec's Avatar
I would strongly recommend running a 30A relay in the circuit. You can get one and a connector for it at any decent parts store. I would wire it so the switched part of the relay is hot key on, and run your in-car switch to ground (to turn it on and off). No need for any fires!! You should still use your inline fuse for the main power feed going to the relay.
Old Jun 30, 2006 | 07:00 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
I think it is my exaust heating my pump up. I have open headers for now and i got under the car to feel the pump and on my way back out from under it i hit my arm on the panhard bar and it was hot as hell.
Old Jun 30, 2006 | 08:34 PM
ZEEYAA's Avatar
Car: 1991 Z-28
Maybe you should at least put some short turn downs on it.
Old Jun 30, 2006 | 08:49 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
I am probly gona put my mechanical pump back on for now and put the holley on when i get my exaust done.
Old Jun 30, 2006 | 11:08 PM
Lo-tec's Avatar
Why don't you put the exhaust on now and then start another thread about having the same problem with your fuel pump?
Old Jul 1, 2006 | 06:47 AM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
I will put exaust on when i have the money. Why dont you think the pump will work then. I have done everything everyone has said and it is still heating up.
Old Jul 1, 2006 | 10:33 AM
Lo-tec's Avatar
So you've re-wired it with heavier gauge wire (both hot and ground) and hooked up a return style regulator and a return line?
Old Jul 1, 2006 | 02:46 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
I rewired it with 10g wire and emailed holley and they said the pump should circulate enough fuel through it when the motor is idleing so i dont need a return style regulator. I am going to put one on it anyway when i put it back on.
Old Jul 3, 2006 | 11:30 PM
91CamaroRS305's Avatar
Car: Only a daily driver, but comin home
Engine: I have one that runs ;)
Transmission: Caged hamster that runs really fast
Axle/Gears: They are round, I know that much
If the pump is in the back open headers shouldnt affect the pump that far back. Check the grounds on your battery to. You should have a main one grounded out on the engine block and anther 10 guage or so wire grounded to the body, and a strap from the engine to the body. Also the relay idea is the best, I run a self wired relay on my pump and have no problems. Check to see the recommended amp fuse for the circuit, I used to run a hard wire switch with a fuse (no relay) and my switch got so hot it melted the plastic panel it was in
Good luck!!
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
