Lots of gas, no power.
Car: 85 z28
Engine: Lg4 305 4bbl
Transmission: 5-speed
I have an '85 305 z28 with a non-cc qjet. When I floor it, the secondaries open but the RPMs will not go over 3000 and I won't gain speed. It has a hard time getting up even gradual hills; I can have it floored in second gear and have a hard time exceeding 15 mph.
I have adjusted the timing and tested it at 6*, 8*, and 10* and still have the same problem. Could it be a carb problem? What could be causing this?
Car: 1991 Z-28
Engine: 383 / TPIS MINI RAM
Transmission: 700-R4
Axle/Gears: MOSER 9IN 3.89
Without knowing anything else, like is it a rebuilt carb, or new, did it run alright before you installe it etc. My guess it that the secondary is way fat. Like I said just a guess without knowing more history.
mine does something VERY similar to this. TON of power in the first 2 gears, after that, it falls on its face and has a hard time goin past 3K RPM as well. The only conclusion I have, is I have vacuum leaks, and my carb isnt' adjusted correctly for my engine (cause I don't know much about carbs yet
Good luck
Good luck
Car: 1986 Pontiac Trans Am
Axle/Gears: 9 bolt/3.27
is the choke coming on? mine had a problem with the choke coming on a couple of years ago; as soon as i disconnected the choke it ran fine, but started a little harder
1992 Trans Am
May 10, 2023 07:19 PM
