Mechanical pump aided by electric,with an on/off option?
Old Jul 13, 2006 | 12:16 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
I am currently running a Holley "Blue" #12-802-1 electric fuel pump with a Mallory #4309 bypass regulator with -6AN lines.I have had a few of these pumps go bad shortly after installed and want to come up with a better, fail safe fuel system.The car is 90% street & 10% strip so I want a more reliable fuel system as I only need a max effort system 10% of the time.I like the idea of a mechanical pump as it is a much cleaner, and IMO more reliable system and more than adequate 90% of the time I drive the car.Only problem I see is if the car gets faster/hooks better at the track I may need to step up to an electric pump to fight the g-forces on the fuel flow at launch.So after searching here (Damon) and elsewhere on the net I have read and like the idea of running both an electric and mechanical pump.
I am planning to run the Holley "Blue" I already have into a Carter mechanical pump.I would like to have the "Blue" electric pump on a toggle so I can manually turn it on and off as needed.That way I can drive on the street with just the mechanical and if I plan to get on it/go to the track I can turn on the electric pump to aid the mechanical.Would the Carter mechanical pump be able to pull fuel through the electric pump when it is off?Would I need to run a regulator for when I do have the electric pump on or will the mechanical act as the regulator in the system?Has anyone ever done this with an on/off switch?
Old Jul 13, 2006 | 01:09 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The mechanical pump will regulate in that setup. I don't know if the mechanical pump is going to draw through a stalled electric all that well, though.
Old Jul 13, 2006 | 11:43 PM
Rick King's Avatar
Car: 1987 TA
Engine: 350 stock/twecked
replace the blue pump or rebuild it holly also has a red pump that has its own regulator
I do not think the mechanical pump will do what you need it to withoutr removing the electric pump
later
and
GB
rk
Old Jul 14, 2006 | 12:04 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Supposedly the different colored Holley pumps are all the same, the only difference between them is the bypass spring.
Old Jul 14, 2006 | 10:27 PM
Rick King's Avatar
Car: 1987 TA
the red pump dose not need a regulator by design they run at the proper line presure. The blue pump runs at a higher line presure and requiers a regulator.I went through all this with the Holley techs 2 years ago for the 68 ss
later
and
GB
rk
Jorlain
Aug 24, 2022 05:11 PM
RazorN8
Jan 7, 2022 11:44 AM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
Dialed_In
Aug 20, 2015 01:45 PM
