cfm rating
Old Aug 9, 2006 | 05:37 AM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
cfm rating
Looking on barry grants website at the demons, a speed demon 850 has a venturi size of 1.562 and a butterfly of 1 3/4.....scrolling around to a race demon 1000 cfm shows a ventrui of 1.562 and a butterfly of 1 3/4. I`m looking to go with a bigger carb with the new engine (496 bbc 14.1 with 270 duration and .708 lift) but should I just keep the 850 or move on to the dominator series carbs which start with 1.75 ventruis and 2.00 butterflys? the entry to the ventruis makes 150 cfm difference or am I comparing apples to oranges
Old Aug 9, 2006 | 06:43 AM
contact's Avatar
Engine: sbc 350
'monkey,
perhaps you should measure the partial vacuum
in the intake manifold, at WOT, to see how
much you might gain
Old Aug 9, 2006 | 05:05 PM
well, say it was running WOT with 1.5 inches, will a bigger carb help that?
Old Aug 10, 2006 | 05:04 AM
contact's Avatar
Engine: sbc 350
1.5 inches,
is 5 percent of an atmosphere.
and includes aircleaner, and other drag from piping.
is 2 or 3 percent more, worth it?
PurelyPMD
May 5, 2016 04:57 PM
okfoz
Oct 13, 2015 02:19 PM
LT1Formula
Oct 8, 2015 08:34 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Dragonsys
Sep 25, 2015 03:51 PM
