87 formula 305 carburated
Old Aug 15, 2006 | 06:32 PM
elcamman50's Avatar
Car: 1987 formula
Transmission: 700r
Hi everyone. I am new here, but not to firebirds or camaro's. I have a 87 Formula with the 305 and quadrajet carb. Why is there a electric fuel pump and a mechanical one? The one in the tank is shot. Can I run just off the mechanical one? I would hate to have to cut my exhaust system just to get that da_n thing out! Any help would be greatly appreciated. Thanks for your time.
Charlie
Old Aug 15, 2006 | 09:11 PM
daveSS1987's Avatar
Hi Charlie,
That's news to me, but I'm not 100% Camaro/Firebird oriented, since i have a 1987 El Camino SS, with the same CCC quadrajet. The Elky does not have an intake pump, relies completely on the mechanical one. So since your car has the same carb as mine it will run great on the mechanical pump, the in-tank pump may be more of a clog since it is not working. It may work better if you take out the in-tank electric pump and also add a Holley mechanical pump, which gives you better fuel flow than a 20 year old original stock pump.
Dave
Old Aug 15, 2006 | 11:26 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
It had the in-tank pump to help prevent vapor lock. If you try to let the mechanical pump suck through an inoperative in-tank electric pump, you are going to reduce the capacity of the mechanical pump, and greatly increase the tendancy for vapor lock.
If the in-tank pump has gone bad, the only real choices are to replace the pump, or remove it. You don't have to cut the exhaust to get the tank down, just drop it out of the way.
Old Aug 16, 2006 | 12:51 AM
elcamman50's Avatar
Car: 1987 formula
Transmission: 700r
Thanks a lot for the information. I will probably just replace it. It's not that expensive (around 40 bucks at autozone). You guys are great. Thanks again!
Charlie
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
Cleotiz
Jan 6, 2018 08:56 PM
ambainb
Aug 29, 2015 12:43 AM
mrestrictrplate
Aug 27, 2015 09:37 AM
bdads
Aug 24, 2015 06:01 PM
